Which video encoders support the SSE4 instruction set? I currently have tmpgenc plus and the main encoder 1.5 and I know the tmpgenc version I have doesn't but I am not sure about the main encoder.
DivX 6.6 codec and greater carry instruction set for SSE4. If your computer details are up to date (Athlon 2800+), you will not be able to take advantage of it.
I am looking for an mpeg 2 encoder that will support these. I have one the new intel quad core cpu's that supports sse4. I have heard that encoders that can take advantage of these instructions are much faster. I have and encoder for doing avi's but I was wanting one for encoding to dvd format that supported this.
I am unaware of any MPEG2 encoders that support SSE4.
MPEG2 is slowly dieing out, I doubt there will be much active development for this -
"are much faster" .. yes you can have gains up to 200%, in some specific routines and specially chosen circumstances.
More normally these things get you at best 10% speed increase, the rest is down to a faster CPU speed, faster memory and other factors.
These instructions seem to help in motion estimation (or GMC, warp points in divx/xvid). A GPCPU would work better, with native CUDA code..increase of 1000%? sound good?Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
Installation/Uninstallation instructions
By Jirka Cech in forum ffmpegX general discussionReplies: 57Last Post: 24th Apr 2012, 16:45 -
Instructions for DVDShrink with ImgBurn?
By JohnnyBob in forum DVD RippingReplies: 29Last Post: 9th Sep 2010, 15:00 -
Need instructions on how to use avi.net
By snafubaby in forum DVD RippingReplies: 1Last Post: 21st Dec 2008, 18:05 -
Camera Mount Instructions for a Bicycle
By Soopafresh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 11th Jun 2007, 15:42
