I have over 50 avi files I need to merge. I'm looking for a program that will output the same bitrate, frame rate and audio rate without having the videos go out of sync.
In case you're wondering, all video and audio are encoded at 3000kbps and 224kbps respectively.
I've tried Allok Video Joiner & Ultra Video Joiner but they go out of sync and Avi Demux & Virtual dub are just terrible!
Suggestions are welcomed
Results 1 to 10 of 10
Well you could also try AVI-Mux GUI.
http://www.alexander-noe.com/video/amg/ -
I use Divx 5/6.7
The problem I have with Avi Demux; i'll try to explain this the best I can. If a start appending 3 or 4 files, the output will generate 1 to 2 secs of sound from previous files.
For example, once the files are merged, on playback I will hear 1-2 secs of file 3 on file 4 and so on and so forth. It's really annoying.
I'm not sure if anyone has ever experienced anything similar, if so, is there a setting that needs tweaking to prevent that from happening. The version I use is Avidemux 2.4 (r3600) -
Recent SVN build?
http://avidemux.razorbyte.com.au/
Did you allow it to rebuild frames/index VBR? You can manually rebuild frames by tools=>rebuild frames
How did you encode these .avi files? What software? What audio codec? -
Actually another related problem (but only for .mp4 container) is encoding output is VFROriginally Posted by tinker
If you are encoding, the .mp4 wrapper is b0rked right now for the last few revisions (VFR encodes instead of CFR), there is a patch in the development thread. But all copying is affected. But AVI container doesn't support VFR, should it shouldn't be affected in the OP's case
Scroll down
http://forum.doom9.org/showthread.php?t=108784&page=46 -
These are the specs of each file:
Video
codec -> Divx 6.7
reso: 640x512
frames: 60 fps
bitrate: 3000kbps
Audio
codec MPEG-1A L3 -> MP3 CBR
Sample 44100 hz
rate: 224kbps
Software used Virtual Dub
need free software recommendation for cutting and joining media files
By xyz123 in forum EditingReplies: 1Last Post: 20th Aug 2011, 03:41 -
Easiest software for compilation, cutting/joining?
By jiopi in forum EditingReplies: 0Last Post: 14th Oct 2010, 12:31 -
So what's the best software for joining mpeg-2 files together?
By snafubaby in forum EditingReplies: 1Last Post: 23rd Aug 2009, 03:15 -
Converting, cutting, and joining audio files in an only software!?
By coxanhvn in forum AudioReplies: 4Last Post: 22nd Feb 2008, 23:44 -
Please suggest a software for me for joining DVD discs.
By csh in forum EditingReplies: 3Last Post: 9th Jun 2007, 22:29
