Hi,
I have a 580 line Helmet Camera with Yellow composite feed. I am attaching this to my microlight wing for filming the cockpit and flight, then editing into DVD videos , just to capture trips round France and Scotland so that when I am old I can "remember the day ". This works 100% when using a DV tape camcorder. However , I would really like to set up a touch screed PVR recorder that I can mount in the cockpit. I was thinking of something like the Archos 605.
Here's the rub- I can't get answers to the following and when I do get info I don't understand the answers![]()
Can I take an AV in feed to PVR ? Which PVR's could take feed?
Camera is 580 line Pal format, what resoultion and format would be recorded to the PVR ? i.e. 480 * 600 @ 30 FPS - Is this lower or higher quality than 580 line PAL.
I understand AVI format I think - What is recording in Composite to Mpeg 4 ? (Does that make any sense?)
Ideal PVR - Would allow composite feed allow for above 10 hours of recording and have ability to take a portable charger - (Microlight runs on 12V system).
Thanks in advance if anyone has any ideas![]()
Recording into a PAL DV camera will get you 720 x 576 @ 25 fps, which is 4:3 DVD resolution, with a minimally damaging amount of compression. Most portable PVRs will record at 30 fps, a lower resolution, and in a heavily compressed format. This will mean difficulty in converting the video back to PAL (in fact, you probably wouldn't convert it back , as it would produce a jerky or blended mess), and you would converting from one heavily compressed format to another, producing another quality drop.
If you must use a PVR type device, look for one that will record at PAL framerates. You will probably have to settle for 640 x 480 resolution and heavy compression though. These devices are not designed for producing archive quality video, but source material for youtube mashups.Read my blog here.
Guns,
Thanks for the reply , no doubt about it I would be looking for greater resolution than 640 * 480. I will set it up using my old digital camcorder
, I have checked and cannot find a new Hard Disk camera with Video in capability.
Thanks for the detailed reply as I know it's a pain to answer Newbie questions. Rest assured I will "Pay it forward" in other forums where I have some knowledge.
Cheers
Garrick
HD wireless from camera to recording device
By channelk in forum Newbie / General discussionsReplies: 1Last Post: 25th Oct 2011, 16:29 -
need help in doing multi canmera recording camera
By nyphantom in forum Newbie / General discussionsReplies: 0Last Post: 8th Oct 2011, 03:27 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Recording from DVD back to Camera
By SteveID in forum DVD RippingReplies: 4Last Post: 18th Mar 2010, 14:03 -
recording from more than one video camera
By wingdude in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2008, 00:31
