Trying to open up a MKV with XVID4PSP and I get an error about DirectShowSource. It says, "DirectShowSource: RenderFile, the filter graph manager won't talk to me
Tried to open the same MKV with MeGui and I get the following:
HUH ??? What ???
Help !!!![]()
I should point out that I haven't had this problem with other MKV files. This particular MKV is H.264 with AAC-LC audio. Doesn't appear to be all that different from other MKV files I've worked with (although most seem to have ither AC-3 or DTS instead of AAC-LC audio). The MKV file does play back A-OK with Windows Media Player so ... is this a problem with ffdshow or Haali Media Splitter or what ???
I'm confused *cry*
- John "FulciLives" Coleman
P.S.
Should I try to uninstall ffdshow and then reinstall etc. ???
*** EDIT ***
I installed some software including some samsung media software (thinking of getting their iPod Touch like MP3 player so wanted to check the software out). This happened after that so maybe that program did something "bad" LOL
Well I guess I solved the problem (knock on wood) ...
1.) Uninstalled ffdshow which made me reboot
2.) Installed ffdshow
3.) Did not ask me to reboot but did anyways
4.) Now it works as it should
Go figure *shrugs*
Vegas Pro 9.0 (64bit) won't see installed Filter/Plug-In
By mltwitz in forum EditingReplies: 1Last Post: 26th Aug 2010, 14:16 -
AVISynth Error DirectShowSource: Timeout waiting for graph to start - .m2ts
By onesikgypo in forum Video ConversionReplies: 2Last Post: 22nd Jun 2010, 22:30 -
RipBot error -- DirectShowSource : Timeout waiting for graph to start
By crankharder in forum Blu-ray RippingReplies: 10Last Post: 20th May 2010, 10:19 -
Need help with AutoGk - DirectShowSource
By patrickj0781 in forum Video ConversionReplies: 0Last Post: 22nd Feb 2010, 11:23 -
frequency response graph
By siluet in forum AudioReplies: 13Last Post: 10th Feb 2010, 14:11
