hi all... I have an avi movie, which plays fine in quicktime, but i need to add subs to it and when i load the movie and sub into ffmpegx and render out the new movie it loses the sound... anyone have any ideas as to why?
Actually I seem to have gotten it to work by closing iTunes... Weird I know...
On another note, when I add AVI footage into FFmpegX it automatically renders it out as an AVI, is this the best option? WHen it does this it seems to half the files size so much be really compressing it, how can I use no compression?
AVIs are already compressed so almost anything you do to transcode the video will do some re-compression which, if you're not careful, will degrade the quality. The output format depends on where you intend to use that video in the future. As I use a video iPod and AppleTV, my format of choice is the "iPod H264 640w" setting but I do modify the settings a bit to maintain quality.
AVI to DVD Loses a Few Frames
By BinaryRock in forum Video ConversionReplies: 0Last Post: 28th Jan 2010, 17:56 -
Louder sound via ffmpegX
By maruz in forum ffmpegX general discussionReplies: 2Last Post: 2nd Oct 2009, 04:05 -
conversion loses sound half-way through
By santino_avi in forum Video ConversionReplies: 5Last Post: 21st Oct 2008, 11:35 -
PinnacleStudio8 LOSES AUDIO during import of .AVI files
By DivXterminator in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jun 2008, 08:43 -
My player loses sound after forwarding.
By kevs in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Aug 2007, 17:23
