If i want to convert an avi file to divx with virtualdub, how do i know the data rate?
Also, how can i reduce e.g. an avi file of 20Megs to a divx file of only 10(it's only an example) ?
vcdmaker
haha... at a glance i thought your post said "Divx : date rape"
now whats sicker... that i thought thats what it said... or that i looked at it anyway.
but anyway... with data rate, do you mean bitrate?
and with divx it will cmpress the file a lot... the 20 meg file i asume is just uncommpressed aiv cause you didnt specify otherwise, it should shrink the file cuite a bit... if you download a bitrate calculator you can tell what bitrate you need to set it to to get the desired file size. -
yeah,
but how can i compress that file of 20Megs, to divx, without losing too much quality? If i set the bitrate lees than 910kbps, then the divx file lost a lot of quality.
:roll:
vcdmaker -
you cant... the only way to lower the file size is to lower the bitrate. unless there is some magic wand i havnt found out about.
MPEG Streamclip "limit data rate" disabled
By Dignan. in forum Video ConversionReplies: 7Last Post: 23rd Nov 2011, 12:59 -
avi data rate too high?
By hello2000 in forum Video ConversionReplies: 5Last Post: 3rd Aug 2010, 10:43 -
Data rate for HD video
By spandau in forum EditingReplies: 3Last Post: 21st Nov 2007, 13:23 -
How total data rate is calculated?
By Netozai in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2007, 15:47 -
DivX to MPEG2 conversion - ideal data rate
By danniballoon in forum Video ConversionReplies: 3Last Post: 7th May 2007, 15:28
