i need help on how to split a dvd or vro file into individual clips for easy editting. is it possible? i use a sony DVD handycam with a DVD-RW disk loaded in. I make many individual shots like about...5 probably lasting 3mins each. when i'm using the VR format i can easily erase them but when i put them in the computer(the DVD disk in the drive) and convert them(with AVS video converter), all of the clips merge into one. I havent tried to use the regular format to get individual clips but i will. Is there a way to split a dvd vid into many little clips. I'm not looking for chapters i need to get individual clips from individual shots taken from one disk. btw! i came across something that might help but i dont know how to use it... it's a program called DVD shrink. ppl say that it can help on making mixed dvd or a dvd that uses stripped clips from other dvd and puting it together forming one dvd.
Please help. Thanks!
I would try tmpgenc dvd author and import the vr format and see if it imports them as separate clips. Or else can you split them directly in tmpgenc dvd author author after you imported them.
ok o got the program and i imported the files from the disk to the comp. What to do next? i see the shots i made but they are in chapters.
Splitting Mpeg-2 DVD files..
By Veepa in forum EditingReplies: 2Last Post: 11th Mar 2010, 04:25 -
HELP: DVD-to-Divx 100% quality, time-splitting... for youtube
By andwan0 in forum DVD RippingReplies: 7Last Post: 9th Sep 2009, 05:50 -
Splitting 8GB DVD into 2 single layer dvds
By omega_weapon in forum ComputerReplies: 4Last Post: 16th Aug 2008, 11:17 -
Splitting episode dvd to 2 discs
By parman in forum EditingReplies: 3Last Post: 12th Sep 2007, 16:05 -
Splitting VOBs for burning to DVD ?
By paulwilko in forum Newbie / General discussionsReplies: 6Last Post: 5th Jun 2007, 03:37
