Here's the scoop.
Two Xvid encodes. One (called "correct") when shown on TV and computer has the proper
black bars top and bottom of the screen...all looks normal.
This one below(called "incorrect") has no black bars top and bottom and the picture
is basically full screen. Both are from the same source - encoded by a friend.
What happened?
Can this be fixed or am I stuck?
The first one is letterboxed (it has a ~720x400 image with 88 lines of black top and bottom) and should have the DAR flag set to 4:3. The second one isn't letterboxed but should have the DAR flag set to 16:9. Use MPEG4Modifier to do so.
Note, not all players will respect the DAR flag. -
THANKS!!!!
I couldn't think of the name of that damn tool.
It works.....so far.....at least on the computer anyway. I'll
try on my HDD to TV (Trekstor Movie Station) tomorrow. -
I used a combination of the GSpot posts, hech54's description, and knowledge of common mistakes made in creating Xvid AVI files.
The first video had a 720x576 (5:4) frame but a square pixel encoding (1:1 PAR). Hech54 said it played back with "proper black bars top and bottom". That means the black bars are part of the picture. The implication is that this was a 16:9 video letterboxed in a 4:3 DAR frame (typical of a widescreen cap from VHS tape, for example). He probably didn't notice that it was playing back with a 5:4 aspect ratio (because 4:3 DAR wasn't flagged) rather than 4:3.
The second had the same properties according to GSpot but Hech54 said there were no black bars. He didn't mention if the picture looked squished horizontally but I guessed it was. Since the frame size was 720x576, typical of a DVD rip, I guessed it was a a DVD rip, not corrected for square pixel encoding, but also not encoded with the 16:9 DAR flag. -
Thanks for the explanation, jagabo! I'm starting to get the hang of it.
ways to determine the bitrate of your dvd to xvid or h264 encodes
By codemaster in forum DVD RippingReplies: 2Last Post: 21st Sep 2011, 21:25 -
Speed up xvid encodes?
By rhijaen in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2010, 00:48 -
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 00:46 -
Xvid messes up when widescreen
By crt in forum Video ConversionReplies: 1Last Post: 4th Nov 2008, 06:11
