i have problem after authoring couple of vobs using dvdshrink.
i have 3 chapter from some series which i ripped from dvd in order to add subtitles.
since there was problem with the structure (i think) of the dvd i couldnt add them back with menu using vobblanker and i decided to leave them without menu, so in order to join them toghter to 1 dvd i chose dvdshrink , chose reauthor and back it up and burned it .
here is the result that i get .
when entering the first disc with episode 1-4 the disc had stucked, i downloaded the latest version of dvdshrink do the process again burn it and it was ok.
than i did the same to episodes 5-7 and same thing happend. the disc stucked. i did the process again , burned it again but this time same thing happened the disc stucked.
anyone know what could be the problem , or can suggest different method to join the episodes (something easy to use like dvdshrink) ?
im using good quality dvd+r verbertime.![]()
Results 1 to 9 of 9
ahhhh , sorry for not mention the burning method i used.
but i used exactly as you said.
imagburn and than dvddecryptor for burning. -
I have had dvd shrink go wrong, just reinstall it
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
If you are using DVD Decrypter for burning, it's almost as out of date as Shrink.
Shrink is still a good program for 'shrinking' down the size of a DVD, but, as mentioned, ImgBurn is a much newer and more reliable burning program for newer burners and DVD media. Written by the author of DVD Decrypter.
And many newer DVDs need a ripper like DVDFab HD Decrypter to rip before processing with Shrink, though that doesn't sound like your problem. -
the version was the latest.
is there another simple way for adding multi independence vobs to one (menu not needed) ?
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 12:24 -
AVStoDVD 2.3.2 - Process aborted during DVD Burning Operations
By Mark97213 in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2010, 15:05 -
Imgburn getting stuck Burning DL Dvd+R
By Amzin in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2010, 17:33 -
Can DVDShrink be set to use ImgBurn for burning?
By RoyGBiv-inRI in forum DVD RippingReplies: 7Last Post: 21st Jul 2007, 14:17 -
Any suggestions for getting educated on burning process?
By Cathyq in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 09:44
