I have a movie i want to burn to a standard vcd. I encoded it from divx to .mpg. The .mpg is fine but the problem i have is that it is 1.1 GB. So must i Split this up into differents parts. Or what should i do. Can someone please help me. Thank you.
Try using tmpgenc. There is the Tools options which allows you to cut & merge. Cut it to fit into 2 CDRs.
Why is my sig so big?
By hech54 in forum FeedbackReplies: 1Last Post: 28th Apr 2012, 03:14 -
dvd way too big?
By item9 in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2009, 00:41 -
Size is to big
By g_pentium in forum DVD RippingReplies: 9Last Post: 6th May 2008, 04:36 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 23:51 -
Movie seems to big
By DarkLogan in forum Newbie / General discussionsReplies: 5Last Post: 17th Aug 2007, 15:18
