I have some video ripped form HDTV. All of them are in ratio 16:9. I want to resize them to the ratio 4:3 (640x480) by creat 2 black bar on the top and bottom of the video by VirtualDub but I don't know how to do it! Can somebody help me, please!!!
I changed your topic subject. Just "Does anybody know" doesn't say anything aboout your topic.
Have you played around with the resize filter in virtualdub? Under Video->filters and set the new size to 640x480 and select the letterbox to aspect ratio 4:3. View the preview to check that it looks okey. -
why?
i also think it's good form to at least post an image of unprocessed source."I'll give you five dollars if you let me throw a rock at you" -
Well, resize the video to 720x360, then add borders (60 pixels on top and bottom). An AviSynth script is:
This should work (or something close to this).Code:avisource("myvideo.avi") bilinearresize(720,360) addborders(0,60,0,60) add convertto whatever colorspace you need.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Did you try virtualdub?
Import the avi, add the resize filter under Video->filters and click on it to change to 640x480 and select the letterbox to aspect ratio 4:3.
Select Video->Compression and choose a video codec like xvid codec.
Select Audio->Direct Stream Copy
Select File->Save as avi -
Question: why would you want to?
if you are putting them on a DVD you should leave them as 16x9 and set your DVD player to letterbox the DVD for a 4x3 TV.
Black borders all around video
By techboy_66 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th Oct 2010, 17:01 -
Need a program that adds black borders
By zubiri in forum Authoring (DVD)Replies: 2Last Post: 14th Sep 2010, 19:42 -
Cutting black borders
By HamishT in forum Authoring (DVD)Replies: 17Last Post: 4th Mar 2009, 17:53 -
Black Borders won't go away!!!
By mirandapanda in forum Newbie / General discussionsReplies: 6Last Post: 10th Sep 2008, 01:49 -
how do you get rid of black borders when trying to convert file to DVD
By whodini in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2008, 16:15
