Can FFMPEG generate .WMV files with WMV9(WMV3) video and WMA9.2 audio? If so, what would be
the command line to generate one with video: bitrate 600K and audio: bitrate 32k and sample of 48k?
I have searched high and low... I think I am more confused now than when I started this quest...
Thanks much-
Andrew
	no
 use microsoft"I'll give you five dollars if you let me throw a rock at you"
	Thanks, I thought not... further digging, it will DEcode but not ENcode WMV9. Well, we can always hope for an updated build that supports VC-1!!
 Im using NIC's WMEncode, works much better than WME. I was however, looking for a command line solution for a batch processor.
 Thanks,
 Andrew
	no
 don;t hold your breathOriginally Posted by RogerTango "I'll give you five dollars if you let me throw a rock at you" "I'll give you five dollars if you let me throw a rock at you"
  What program can I buy so i can make a vid like gopro hero2 vidBy DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 14:01
  [Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 11:50
  downloading a vid from radio-canada.com, but vid isn't available for dwldBy vivimarie in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2010, 12:48
  Vid encodes will only display first frame instead of loop at the end of vidBy SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 23:09
  issues using codecs wmv9 and wma9.1 in ffmpegBy jcor in forum LinuxReplies: 1Last Post: 15th Oct 2007, 09:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
