  1. Member wulf109's Avatar
    Jul 2002
    Sometimes a DVD refuses to rip one file on the disk. Maybe the disk has 12 VTS's on it and VTS_9_1.VOB won't rip,all the other files will. Finish the rip,then go back and select that file that wouldn't rip,select it and rip it indvidually. This often works allowing you to complete the rip. Slowing the rip speed seems to improve the readability of "bad" files.
    USA
    You might want to add what program you are using to rip your DVDs.
