  1. Member coody's Avatar
    Jan 2005
    Do you think how many GB USB at least to save one DVD movie? Is 4 GB enough? In addition, do you know how to set the code to the USB under the Win XP in case the drive is lost?
    Apr 2004
    Miskatonic U
    Well - it depends on the DVD. A DVD-R is 4.38 GB, and a DL disc is over 8BG, so any DVD that runs close to a single layer size or fits on a dual layer won't fit on a 4GB USB key.
    That said, if you run the DVDs through AutoGK you can probably fit 4 - 6 movies in the same space.
    I don't understand the second part of the question, so I can't give you an answer there.
    Read my blog here.
