    Feb 2002
    TORONTO, CANADA
    NOW I WANNA KNOW HOW TO CONVERT 2 .AVI FILES (CD) TO 2 VCD CD'S
    couse i have a few movies that there are 2 avi files to make a movie. and i don't wanna use 4 cd's to make them into VCD'S
  2. this is VERY complicated...
    move your mouse to the left, you may have adjust its position up or down as well. once your mouse is over the word CONVERT press the left mouse button once. the first 2 guides explain in detail how to do what you want.
    thanks for your intrest in this forum, please come back again after you have explored the site that the forum is here to support.
    peace out,
    dumwaldo
    AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
    Jul 2001
    One Step From Hell
    !!!ROTFLMAO!!!
  4. just for the record, the size of the encoded mpg has nothing to do with the avi size. the size of the mpg depends on how long the movie is. if you encode to a standard vcd the mpg will be 1min= 10mb. so if you have 2 avi files that are both 70 mins long they would both be 700mb as vcd.
    and in vcd format you can fit 800mb on a 700mb cd.
