  1. Hi guys
    Using Nero I burnt a few CDR's and find no other machine than my own will read them. I have used both AVI and Mpeg but no luck. I have the latest window down loads so I am scratching my head on this one. I am using premier 6.
    Perhaps I am not using my tools correctly. Any help will be appreciated.
    Pat
  2. happens to me all the time with audio tools...your burner is cheap..happened with my old burner 4x4x32 acer
  3. PCs need a specific codec installed to playback video that uses that specific coded. Use one of the standard codecs if possible, or MPEG-1 in VCD-compliant format. Or better yet, straight uncompressed AVI.
