My file mkv has 1 video (avi), 2 audio (aac), 1 srt,
I want to del 1 audio and replace srt by ssa, then i extract mkv.
But(
I use Media Info in K-Lite Mega Code pack)
the mkv orginal
then I extract the videoComplete name : H:\Temp\Love_Hina_Christmas_Special.mkv
Format : Matroska
File size : 695 MiB
Duration : 45mn 28s
Overall bit rate : 2137 Kbps
Movie name : [a4e]Love Hina Christmas Movie
Encoded date : UTC 2004-09-17 12:11:20
Writing application : mkvmerge v0.8.9 built on May 6 2004 19:48:43
Writing library : libebml v0.7.0 + libmatroska v0.7.0
Video
Format : MPEG-4 Visual
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 45mn 25s
Width : 704 pixels
Height : 528 pixels
Display aspect ratio : 4/3
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Title : [a4e]Love Hina Christmas
Writing library : DivX 5.2.1 (WaffleDay) (UTC 2004-09-08)
Language : Japanese
what happen with 45mn 28s-36mn 25s =9mn 3s ?Complete name : G:\Temp\Love_Hina_Christmas_Special_Track1.avi
Format : AVI
File size : 653 MiB
Duration : 36mn 25s
Overall bit rate : 2506 Kbps
Writing application : mkvextract 2.3.0
Video
Muxing mode : Packet Bitstream
Codec ID : DX50
Duration : 36mn 25s
Bit rate : 2501 Kbps
Width : 704 pixels
Height : 528 pixels
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.224
Stream size : 651 MiB (100%)
When I watch file avi, it is full, but it seems the timer cout up a little quickly than file mkv
Because there is difference duration so i can't synchronize the audio and video
Results 1 to 12 of 12
How are you extracting it to an avi? What software?
Try using mkvmergegui
Checkmark the files you want, uncheckmark the files you don't want. Add the .ssa file, then press merge -
probably vfr,
if you just want to remux, with one audio and alternate subs,
then you (probably) have to remux to mkv
if avi, is the aim.
then you'll have to re-encode
tripp"I'll give you five dollars if you let me throw a rock at you" -
i used MKVextractGUI to extract and mkvmerge to merge (all in mkvtoolnix)
But i dont understand what going on, while duration file mkv is 45 minutes but the duration of file video avi extract from mkv is 36 minutes
@45tripp: amazing, you found the main reason, but i need an advice, i will change vfr to cfr or use merge to mkv and execute some special script needed -
was that a question?
but i'll say it's a mistake to demux with mkvextract and then remux.
overly complex.
import media directly into mkvmerge,
select streams you wish to remain,
remux."I'll give you five dollars if you let me throw a rock at you" -
Just to be sure, are you running the latest versions of MKVExtractGUI/MKVMerge and mkvtoolnix, all installed to the same directory?
If cameras add ten pounds, why would people want to eat them? -
of course.
Notice that i have trouble with another file, not the file which is mentioned in first post
Extract SRT From MKV
By Valentin in forum MacReplies: 4Last Post: 12th Sep 2014, 20:14 -
mkv extract and mymp4box problems
By edy_smf in forum Video ConversionReplies: 1Last Post: 27th Apr 2011, 04:24 -
MKV Extract and Merge
By b1tbull in forum DVD RippingReplies: 2Last Post: 24th Aug 2010, 04:50 -
How to extract audio from a MKV?
By takearushfan in forum AudioReplies: 3Last Post: 23rd Jul 2010, 23:51 -
Chapters extract for MKV
By jameson_uk in forum Blu-ray RippingReplies: 10Last Post: 28th Feb 2009, 11:35
