hello guys,
man, i am struggling with this ffmpeg x the whole day, and reading your posts i get some comfort that i am not alone, but still... cant find my hands and feet in it... am trying to convert some quicktime or AVI files to Flash, in order to upload them to my website. i downloaded the ffmpeg X for Mac, plus the 2 other components, but couldnt really figure out how to install the flvtool 2 ....
then, i dragged the QT and AVI files into ffmpeg X, and try to convert them, but i got weird files, which wouldnt play, even on the VLC player which i downloaded... (i tried the Invert Mapping check box, but it still didnt work..). here are the messages i get:
without checking the Invert Mapping box:
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Sun Sep 14 20:35:59 PDT 2008
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x4701fc]negative ctts, ignoring
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/Aylam-back up disk/clips for website/Autumn Dawn.mov':
Duration: 00:01:20.3, start: 0.000000, bitrate: 2054 kb/s
Stream #0.0(eng): Audio: lpcm / 0x6D63706C, 96000 Hz, mono
Stream #0.1(eng), 29.97 fps(r): Video: h264, yuv420p, 425x318
Codec type mismatch for mapping #0.0 -> #0.0
After checking the Invert Mapping box:
Sun Sep 14 20:36:48 PDT 2008
Output #0, flv, to '/Volumes/Aylam-back up disk/Autumn Dawn test1.flv':
Stream #0.0, 29.97 fps(c): Video: flv, yuv420p, 432x324, q=2-15, 200 kb/s
Stream #0.1: Audio: mp3, 22050 Hz, stereo, 56 kb/s
Stream mapping:
Stream #0.1 -> #0.0 [sync #0.0]
Stream #0.0 -> #0.1 [sync #0.1]
Unsupported codec (id=0) for input stream #0.0
any idea what i am doing wrong ??
thanks so much !!!!
Linear PCM sound in .mov files with sample rates above 64000 Hz are not recognized by ffmpeg.Originally Posted by Aylam
If you exported this .mov file from some other application, you should bring the sample rate down to 11025, 22050 or 44100 Hz, as only those are supported by the FLV format (22050 Hz being most common). By doing that, the re-sampling only happens once.
Thank you very much ! i'll try that tonight !
indeed, i exported these .Mov or AVI files from Final Cut Pro, where I edited them. if we're already at that, could you recommend the best settings (video and audio) i should use when exporting these files from FCP, so that they are optimal for convertion into FLV files by ffmpeg x ? (for example, is Linear PCM the best choice at all ? is H.263 the right choice for the video ? etc...)
Thanks so much for your help !
Aylam
hello again,
ok, so i tried the Linear PCM sound setting you suggested (22050 Hz), and exported the clip as .mov file, and checked the box for Invert Mapping, and got an flv file. but when i tried to play it in VLC, i got an error message with the following log:
main debug: CPU has capabilities AltiVec FPU
main debug: looking for memcpy module: 2 candidates
main debug: using memcpy module "memcpyaltivec"
main debug: waiting for thread completion
main debug: thread 42903552 (playlist) created at priority -47 (playlist/playlist.c:184)
main debug: thread 42141184 (preparser) created at priority -47 (playlist/playlist.c:210)
main debug: looking for interface module: 1 candidate
main debug: using interface module "hotkeys"
main debug: thread 42139648 (interface) created at priority -47 (interface/interface.c:198)
main debug: looking for interface module: 3 candidates
main debug: using interface module "macosx"
main debug: thread 42049536 (manage) created at priority -47 (interface/interface.c:164)
main debug: adding playlist item `Autumn Dawn-test.flv' ( /Volumes/Aylam-back up disk/Autumn Dawn-test.flv )
main debug: creating new input thread
main debug: thread 43699200 (input) created at priority 37 (input/input.c:265)
main debug: creating statistics handler
main debug: `/Volumes/Aylam-back up disk/Autumn Dawn-test.flv' gives access `' demux `' path `/Volumes/Aylam-back up disk/Autumn Dawn-test.flv'
main debug: creating demux: access='' demux='' path='/Volumes/Aylam-back up disk/Autumn Dawn-test.flv'
main debug: looking for access_demux module: 1 candidate
macosx debug: input has changed, refreshing interface
main debug: creating access '' path='/Volumes/Aylam-back up disk/Autumn Dawn-test.flv'
main debug: looking for access2 module: 6 candidates
vcd debug: trying .cue file: /Volumes/Aylam-back up disk/Autumn Dawn-test.cue
vcd debug: could not find .cue file
access_file debug: opening file `/Volumes/Aylam-back up disk/Autumn Dawn-test.flv'
main debug: using access2 module "access_file"
main debug: pre-buffering...
main debug: received first data for our buffer
main debug: pre-buffering done 1408981 bytes in 0s - 161459 kbytes/s
main debug: looking for demux2 module: 44 candidates
ffmpeg debug: detected format: flv
ffmpeg error: Seeking too far : EOF?
main debug: selecting program id=0
ffmpeg debug: adding es: video codec = undf
ffmpeg debug: adding es: audio codec = mp3
ffmpeg debug: AVFormat supported stream
ffmpeg debug: - format = flv (flv format)
ffmpeg debug: - start time = 0
ffmpeg debug: - duration = -1
main debug: using demux2 module "ffmpeg"
main debug: looking for a subtitle file in /Volumes/Aylam-back up disk/
main debug: looking for decoder module: 26 candidates
main error: no suitable decoder module for fourcc `undf'.
VLC probably does not support this sound or video format.
main debug: killing decoder fourcc `undf', 0 PES in FIFO
ffmpeg debug: libavcodec initialized (interface 3349504 )
ffmpeg debug: ffmpeg codec (MPEG Audio layer 1/2/3) started
main debug: using decoder module "ffmpeg"
main debug: thread 43918336 (decoder) created at priority 37 (input/decoder.c:159)
main debug: `/Volumes/Aylam-back up disk/Autumn Dawn-test.flv' successfully opened
main debug: EOF reached
macosx debug: input has stopped, refreshing interface
main debug: closing input
main debug: removing module "ffmpeg"
main debug: removing module "access_file"
ffmpeg debug: ffmpeg codec (MPEG Audio layer 1/2/3) stopped
main debug: thread 43918336 joined (input/decoder.c:191)
main debug: killing decoder fourcc `mp3 ', 0 PES in FIFO
main debug: thread 43699200 joined (input/input.c:412)
main: nothing to play
main debug: thread 43846656 (input) created at priority 37 (input/input.c:265)
main debug: pre-buffering done 1408981 bytes in 0s - 154532 kbytes/s
ffmpeg debug: libavcodec already initialized
main debug: thread 44038656 (decoder) created at priority 37 (input/decoder.c:159)
main debug: thread 44038656 joined (input/decoder.c:191)
main debug: thread 43846656 joined (input/input.c:412)
main debug: thread 43987456 (input) created at priority 37 (input/input.c:265)
main debug: pre-buffering done 1408981 bytes in 0s - 162508 kbytes/s
main debug: thread 44110336 (decoder) created at priority 37 (input/decoder.c:159)
main debug: thread 44110336 joined (input/decoder.c:191)
main debug: thread 43987456 joined (input/input.c:412)
any idea why it's still not working ?
thank you again !
Aylam
Apparently, the video codec isn't recognized (undf for undefined?). Maybe VLC isn't such a good player for FLV files...Originally Posted by Aylam
Try QuickTime Player with the Perian component, MPlayer, SWF & FLV Player, flvThing, heck, even RealPlayer.
But the acid test is to embed it in a webpage.
Flash support in VLC is relatively recent. Perhaps not all the bugs have been worked out yet, or it may be that you are using an older version. IIRC, versions after 0.8.somethingbigerthan5 are needed.
That said, try Case's suggestions. Something will work!
How to convert a Flash video (*.SWF) to a Movie (*.AVI)
By potatosalad in forum User guidesReplies: 27Last Post: 3rd Jun 2015, 09:02 -
Can I Convert Flash files?
By humphz in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2010, 00:40 -
how to convert avi to flash video 4!!!
By dsl123 in forum Video ConversionReplies: 1Last Post: 18th Dec 2009, 10:09 -
How to use FFMPEG to convert avi/wmv to 3g2 files(mobiile phone)?
By alfo666 in forum Newbie / General discussionsReplies: 3Last Post: 5th Sep 2009, 17:10 -
ffmpeg won't convert files from Pal to NTSC, mpegstreamclip does
By ruggerjvd in forum ffmpegX general discussionReplies: 2Last Post: 8th Jun 2009, 08:39
