I have been trying to find an application that will let me extract my favorite scenes from my movies (DVD's) and put them on to one DVD, just like the dts sample discs with that same quality? I downloaded a demo of Cinematize, however it is too limited to really put to a test and I do not understand the final format? a DVD is made up of video_ts file and I am happy with that quality, I use a DLP projector and a 50" HD plasma, I have tried imovie which is time consuming and has poor quality. Toast 9 reports to have this kind of feature, however the information is a little vague? any advice would be most welcome. Thank you for taking the time.
Kind regards, the turdburglar.
use MPegStreamClip (and the Apple codec MPEG2, not expensive)Originally Posted by turdburglar
to make a dvd, give your resulting mpeg (from MPSC) to a soft that do that (toast or other)and put them on to one DVD
no need to transcode to DV, you just trim in MPSC and Menu item "file">"Convert to mpeg…" (no re-encoding[...]Cinematize
PS: about iMovie quality, the new iMovie7 (from iLife08) give you poor quality. The version iMovieHD = v6 (you can download it for free on Apple site) give you the same quality as FinalCut (I just talked about quality, not about featuresI have tried imovie which is time consuming and has poor quality.
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
extracting hardsub
By Benjy in forum SubtitleReplies: 0Last Post: 17th Jan 2011, 09:40 -
Software for extracting clips from DVD
By gaurav200x in forum EditingReplies: 2Last Post: 10th Aug 2010, 13:43 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 17:03 -
Extracting audio from .ts
By leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 16:22 -
Extracting Subtitles
By Boiler98 in forum MacReplies: 5Last Post: 24th Jun 2008, 08:21
