Trying out CCE and I imported an AVS file of an AVI for conversion to MPEG2 and the running time is off by 6 seconds. The file runs 1:35:21 according to GSpot but CCE's main window says its 1:35:15. Importing the AVI file itself into CCE also reads as 1:35:15. The number of frames is the same.
When I imported a 1:23:20 PAL AVI into CCE, I got a duration of 1:09:26 (number of frames was the same in GSpot and in CCE).
Results 1 to 13 of 13
6 seconds is the difference between 29.97 fps and 30 fps over a 95 minute movie.
Will the 23.976 ones encode correctly or do you have to go into the profile and change the framerate?
This is why I like HCEnc, it sets its options based on the commands in the avs script and you don't have to do anything else other than set the DC and GOP. With TMPGE Xpress and MainConcept, it still asks you for the framerate and sizing and stuff even if they are included in the script and I guess you have to go in and adjust the profiles or create a new one in CCE to handle certain files. -
I think it's OK, but aren't you going into the main screen to check and adjust the settings anyway? For example, do you check to see if the "Progressive" box is checked, or if it's set for "Zig-Zag" scanning, or if Pulldown will be applied? Did you crop and resize in the script, or are you relying on CCE to do it for you? Me, I have a number of different templates I use for different kinds of video, with a progressive 23.976fps one set as the default, but there are still a number of things that have to be set in CCE, including bitrates, if 4:3 or 16:9 (sometimes), number of passes (sometimes), and quantisation matrix.Will the 23.976 ones encode correctly or do you have to go into the profile and change the framerate?
I'm fairly certain you do more than that, unless you do every encode for the same bitrates or CQ, or DAR, or matrix. CCE is no more difficult to set up and use than is HCEnc.This is why I like HCEnc, it sets its options based on the commands in the avs script and you don't have to do anything else other than set the DC and GOP. -
Yes, I do more than that but I guess the layout is more familiar and appealing to me than CCE's. The main interface of CCE seems like its geared for just dropping a file in and picking a preset. When I load a script into HCEnc, most of the settings are there (if its 23.976, it states it and recommends applying pulldown and the duration is correctly displayed). I set the bitrates and I'm still getting to know matrices. I've used the standard MPEG one and the FOX1.I'm fairly certain you do more than that, unless you do every encode for the same bitrates or CQ, or DAR, or matrix. CCE is no more difficult to set up and use than is HCEnc.
And I'm more used to HCEncThat's interesting because I find the opposite, that CCE's is laid out better and is more intuitive. But that's probably because I'm more used to CCE, and use it more often than I do HCEnc. Both are fine encoders.
yeah cce is built to be template based.
but that's probably a good thing.
it's nice the way you can drag input in and
have a simple intuitive job manager on the main screen.
those are essentially features missing from hc.
I like the tab format of hc though. very clean.
cce's layout is fine,
it's as an encoder that i dislike it.
speaking of layout...
why do you have bbcodes disabled?
and if you must or prefer,
at least edit your posts to something more legible.
tripp"I'll give you five dollars if you let me throw a rock at you" -
I have no idea. I went to the profile and enabled it and re-entered the quote in the above post but it still looks like that but this new one seems to have been formatted correctly.speaking of layout...
why do you have bbcodes disabled? -
An old topic but I tried out inverse telecining a film I had recorded to DVD from VHS in CCE and got an output 6 seconds short of the actual running time. However, I got the correct running time when in DVDLab Pro when I used the "Rewrite GOP Timecode" function so all seems well.
I still like HCEncGUI but at least I better understand the template based CCE. -
... and what's wrong with that?The main interface of CCE seems like its geared for just dropping a file in and picking a preset.
I personally adore CCE's ease of use, and is the best $$ I've spent for an encoder. Although full respect to HC and its users, I personally find that interface awkward. But that's me.I hate VHS. I always did. -
You can go back to the other post in 'edit' and enable BBCode in that post with the checkboxes at the bottom. They are disabled there at present. 'Smilies' are also turned off.Originally Posted by ecc
encoded video duration different than vob duration
By fatcharlie in forum Video ConversionReplies: 9Last Post: 4th Dec 2011, 10:04 -
Finding out the duration of an MPEG file
By firblazer in forum ProgrammingReplies: 4Last Post: 20th Oct 2010, 01:55 -
Xvid4PSP extends the duration of the video file
By mark63534 in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2010, 00:11 -
VOB2MPEG video duration only 3 seconds yet file is complete?
By Rudyard in forum Video ConversionReplies: 3Last Post: 28th Aug 2007, 18:19
