1) Import titles containing LPCM audio into TMPEG DVD Author including chapters.
2) Set audio compression method. Check if free space in compilation is larger then size of titles or VOBs without LPCM.
3) Move each imported video to a new title.
4) Output DVD video to folder without menus.
5) Replace original titles with new ones using VobBlanker. Agree when asked to confirm new streem settings.
6) You are done. In case the new compilation still does not fit on DVD5 compress it with DVDShrink.
Cann't tell it's possible don't tell anything.
LPCM cannot be compressed. It can be converted to AC3, which can be compressed. Is this 2nd step simply a conversion to AC3?
Shure, I just was so excited about the easy way compared to pain in old days and idea to spread the word I messed up the terminology.
I even did not bother to check if this is not common recomended practice.
Excuse me!
Sorry for my bad English.
Apart of that I am not shure if conversion to AC3 is only "just" conversion.
It also reduces the file size. It shrinks it. Actually it does compress. If not the LPCM itself then the audio for sure.Cann't tell it's possible don't tell anything. -
LPCM is uncompressed audio. AC3 is compressed audio, which is why it is (substantially) smaller than LPCM. So compressing the audio does a conversion to a compressed format (Mpeg-1 Layer-2, AC3 and DTS are all compressed to some degree).
Read my blog here.
There's a disadvantage in using TDA instead of Muxman: TDA can (and in most cases will) produce more cells (more than 1 per chapter) than input DVD video has. This needs more attention and extra steps (like splitting cells) at replacement in VOBBlanker.
Yes it is the case. But if it realy creates a problem one can change the order of titles and output project again in new folder then use the problematic title in a safe way. Tmpeg usually creates spare cells in the midle of the disk and not randomly around the project. So if there are many titles to remake, it is still easyer to mux and convert at one click of the button than to first export video, audio(s), subtitle(s) and chapters of each of many titles, then convert several audios, then mux all numerous titles again. It is difficult and time consuming task.
Freeware to compress dvd9 to dvd5?
By Topher5000 in forum DVD RippingReplies: 11Last Post: 27th Aug 2016, 09:49 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
Make AVCHD fit to 1 dvd5?
By alc112 in forum Authoring (Blu-ray)Replies: 16Last Post: 11th Jul 2010, 04:05 -
Best way to losslessly compress LPCM?
By dimtim in forum AudioReplies: 5Last Post: 13th Nov 2008, 12:56 -
fit 3 movies to dvd5
By thecrock in forum Newbie / General discussionsReplies: 9Last Post: 19th Jul 2008, 15:00
