Hi everyone,
I need help in the following situation.
I have a DVD for the movie Independance day, so I try to add a subtitle inside it by using DVDlab pro
following this tutorial :
Code:https://forum.videohelp.com/topic219535.html
But when I Update the Ifo and play the dvd , two problems appear :-
First :-
When I play the movie ( after update Ifo ) , the movie reach to some point and freeze.
The picture freeze. (it seems that it reach to a chapter and can't play it !)
Second :-
Subtiltle colour are not white
But I can fix this
This is not my first time to add subtitle, so I am sure about my steps.
My explaination of the problem ( I am guessing )
The original DVD (video part ) contains two vesions for the movie.
1- Thearical version ( which consist of 54 chapters )
2- Special Edition version ( which consist of 57 chapters )
As I said before , I used Ifo update to update the ifo
So if there is a way to make the ifo did't read the Theatrical version
In other words ; Did't detect "title 2 " ( look at picture 3 )
here is
the VIDEO_TS.IFO ( for the original DVD )
Code:http://rapidshare.com/files/145364107/VIDEO_TS.IFO or http://www.uploading.com/files/VRMO21CK/VIDEO_TS.IFO.html
the VTS_01_0.IFO
Code:http://rapidshare.com/files/145364339/VTS_01_0.IFO or http://www.uploading.com/files/F5FOG0BA/VTS_01_0.IFO.html
And the ifo after adding the subtitle :
VTS_01_0.IFO
Code:http://rapidshare.com/files/145364621/VTS_01_0.IFO or http://www.uploading.com/files/X2BY0KO6/VTS_01_0.IFO.html
Anyone has any idea![]()
Thanks in advance
Sorry for my bad english.
Someone here should be able to give you some assistance. This particular forum is for posting user guides. Moving you to our Subtitle Forum.
BTW, your English is fine.
And welcome to our forums.
His English may be fine but all that colored big font bold crap isn't. This isn't kindergarden.
As far as I know, you won't be able to add subs the tradional way to an angled DVD. Get rid of one of the angles and try again. -
How I get rid of one of the angles ???Originally Posted by manono
thanks for your reply. -
The easiest thing to do, perhaps, is to decrypt using DVD Decrypter in IFO Mode and choose the angle you want. You'll lose the menus, though.
If you want to keep the menus, there are a couple of ways to remove the angle(s) you don't want. I can't find a guide for the PGCEdit/VobBlanker method. This guide uses IFOEdit for the job:
http://www.doom9.org/mpg/ifoedit-multiangle.htm#anglestrip
Problem adding subtitle in MKV
By burple in forum SubtitleReplies: 2Last Post: 7th Nov 2011, 11:34 -
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 14:31 -
Need help adding a subtitle to a DVD.
By chris4556 in forum Newbie / General discussionsReplies: 7Last Post: 24th May 2011, 22:12 -
Problem with adding subtitle to a TV Series DVD
By hellbound in forum SubtitleReplies: 3Last Post: 2nd Sep 2009, 16:56 -
DVD Flick Problem adding subtitle
By MindF in forum SubtitleReplies: 1Last Post: 2nd Apr 2008, 12:49
