Have a couple of 480 x 480 mpg2 files. Used videoredo to cut out the commercials. Normally with this stuff I'd bung it into DVDAuthorGUI and presto.
This time I thought I'd get a little cute with the payware I have and tried DVD Architect. Not thinking, I just knocked up a menu and burned a disk at default settings. Of course, the result was rubbish. Bitrate on one source file was barely 2,000 and the other was about 5,300. And DVD Architect bumped it up to defaults.
What I'd like to do (more steps than essential I suppose) is crop the source so I get the FULL picture within a 4:3 safe area, then burn it without Vegas / DVD Architect trying to up the res to 720 x 480.
Sure I can crop it in Vegas, but is that "clever"? What res would you recommend that I render out as in Vegas?
As far as DVD Architect is concerned, sure I can use 360 x 480 (never tried that before) but what does it need to be fed to make that work?
Cheers.
Results 1 to 1 of 1
Staxrip AAC Audio is causing brain to melt...
By The.King in forum AudioReplies: 3Last Post: 23rd Apr 2012, 16:47 -
Help for the non-functioning brain.....
By The.King in forum DVD RippingReplies: 1Last Post: 6th Jun 2010, 08:04 -
my brain hurts - converting SSA to something DVDAuthorGUI can understand?
By EddyH in forum SubtitleReplies: 17Last Post: 26th Apr 2010, 10:11 -
arrgg Racking my brain about x264 and Subs!
By nickolasj80 in forum Newbie / General discussionsReplies: 2Last Post: 28th Oct 2008, 16:24 -
Something to hurt your brain
By guns1inger in forum Off topicReplies: 12Last Post: 22nd Aug 2008, 17:04
