I notice that most 22" LCD TV's are 1680x1050 which is 16:10 not 16:9. How do they display the picture? Do they stretch the height of 16:9 and 4:3 pictures? What do they do with 2.35:1 ?
A 22" 1680x1080 LCD panel is usually used as a VESA spec computer monitor. LCD-TV panels are usually 1366x768 (square pixel 16:9) at 26" or above. Larger screens may use square pixel 1920x1080. When 16:10 displays are used for TV use, the designer needs to decide whether normal 16:9 TV will show as letterbox, be side cropped, or be displayed as tallish 16:10.Originally Posted by wulf109
4:3 should be scaled to 1400x1050 (or overscanned). This would produce narrower sidebars vs. a 16:9 display. 2.35:1 would have less display height compared to a 16:9 display.
You won't find this in specs. You need to demo the TV.
PS: Low end LCD-TV sets that use computer monitor LCD panels are less likely to produce solid blacks or TV gamma response. You should demo in normal room lighting conditions to evaluate overall contrast and ability to make a true black. Larger display panels are optimized for TV use.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I have a 19" 1440x900 LCD TV (16x10). I has the option to display a 16:9 picture letterboxed (small black bars top and bottom), stretched to fill the screen (distorting the picture), or zoomed slightly to fill the screen (cropping off the left and right edges).
Problem display 1680x1050, the tv says 1920x1080
By duhmez in forum ComputerReplies: 6Last Post: 6th Nov 2011, 05:41 -
Video capture, editing & redndering in 1680x1050 - BIG PROBLEMS
By casparticus in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2011, 17:57 -
Really need help, 1680x1050 is giving me a hard time
By cel in forum EditingReplies: 10Last Post: 6th May 2011, 11:47 -
LCD TV vs. LCD Monitor for PC gaming
By Xenos80 in forum ComputerReplies: 6Last Post: 13th Feb 2009, 00:01 -
Displaying Photos on an LCD Monitor or LCD TV
By jbsiegel in forum DVB / IPTVReplies: 3Last Post: 25th Sep 2007, 13:29
