hi, this my first post and I have some problem with ffmpegx 009y on my mac book pro.
I have an pinnacle usb tv adapter, and EyeTV where I recording some event from tv.
The video recording is in mpg-2 (mpeg-2, 720x576, 10000 kbps, 25 fps) and audio in mp2, 48000Hz, 192 kbps.
The problem is when I using mencoder the audio is mute, if use ffmpeg the audio is ok.
the library is :
The check for audio enconding is 'on'.... and I've tried every solution ... but i don't know where is the problem.Code:macbookpro1:Gara.eyetv antonio$ ls -ltr /Library/Application\ Support/ffmpegX/ total 101280 -rw-r--r-- 1 antonio admin 67 15 Mag 2004 gocrfilter_none.sed -rw-r--r-- 1 antonio admin 271 15 Mag 2004 gocrfilter_nl.sed -rw-r--r-- 1 antonio admin 361 15 Mag 2004 gocrfilter_fr.sed -rw-r--r-- 1 antonio admin 500 15 Mag 2004 gocrfilter_en.sed -rwxr-xr-x 1 antonio admin 281028 15 Mag 2004 gocr -rwxr-xr-x 1 antonio staff 244832 15 Mag 2004 mp2enc -rwxr-xr-x 1 antonio staff 568908 15 Mag 2004 vcdxgen -rwxr-xr-x 1 antonio staff 589400 15 Mag 2004 vcdxbuild -rwxr-xr-x 1 antonio staff 314968 15 Mag 2004 yuvscaler -rwxr-xr-x 1 antonio staff 113352 15 Mag 2004 yuvdenoise -rwxr-xr-x 1 antonio admin 22596 15 Mag 2004 subtitle2pgm -rwxr-xr-x 1 antonio staff 286168 18 Lug 2004 tcextract -rw-------@ 1 antonio admin 501480 16 Apr 2006 mpeg2enc -rwxr-xr-x 1 antonio staff 15869784 29 Apr 2006 mplayer.old -rwxr-xr-x@ 1 antonio staff 15869784 29 Apr 2006 mplayer -rwxr-xr-x@ 1 antonio staff 16655780 29 Apr 2006 mencoder -rw-r--r--@ 1 antonio staff 501480 14 Set 17:34 mpeg2enc.intel
Please, help me
Ciao
Results 1 to 12 of 12
Originally Posted by tomlee59
Code:Encoding started on Sun Sep 14 19:39:03 CEST 2008 MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team FIXME:Hardenabling SSE and SSE2 without detection Mac OSX static build for ffmpegX CPU: Intel (Family: 6, Stepping: 11) CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 success: format: 0 data: 0x0 - 0x68c49850 TS file format detected. DEMUX OPEN, AUDIO_ID: 0, VIDEO_ID: -1, SUBTITLE_ID: -2, PROBING UP TO 2000000, PROG: 0 VIDEO MPEG2(pid=512)NO AUDIO! NO SUBS (yet)! PROGRAM N. 0 Opened TS demuxer, audio: ffffffff(pid 0), video: 10000002(pid 512)...POS=0, PROBE=2000000 VIDEO: MPEG2 720x576 (aspect 2) 25.000 fps 10000.0 kbps (1250.0 kbyte/s) [V] filefmt:29 fourcc:0x10000002 size:720x576 fps:25.00 ftime:=0.0400 The selected video_out device is incompatible with this codec. Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp. Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [scale w=640 h=352] ========================================================================== Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough VDec: vo config request - 720 x 576 (preferred colorspace: Mpeg PES) VDecoder init failed :( Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2)) ========================================================================== Forcing output fourcc to 58564944 [DIVX] VDec: vo config request - 720 x 576 (preferred colorspace: Planar YV12) VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is 1.33:1 - prescaling to correct movie aspect. 1 duplicate frame(s)! 2 to Planar YV12 using MMX2 videocodec: libavcodec (640x352 fourcc=58564944 [DIVX]) High quality encoding selected (non real time)! Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. 1 duplicate frame(s)! Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
Ah, yes. Your file is a "transport stream" (TS). Unfortunately, there is a known bug in mencoder not detecting audio in MPEG-TS files.
If you must use mencoder for some reason, a workaround is to convert the TS file to "ordinary" .mpg using MPEG Streamclip. There's no quality loss -- it just changes the way the audio and video are encapsulated. Then mencoder will work.
You will need the QT MPEG2 component in order for Streamclip to operate on MPEG2 files, however. If you don't already have it, you'll have to buy it from Apple. It's not expensive.
Another option is to perform the audio conversion in a separate step (using ffmpegx's audio-to-audio function), then combine the result of that audio conversion with the video conversion to produce your final result. This procedure is more cumbersome, perhaps, but does not require the QT component.
hello guys,
man, i am struggling with this ffmpeg x the whole day, and reading your posts i get some comfort that i am not alone, but still... cant find my hands and feet in it... am trying to convert some quicktime or AVI files to Flash, in order to upload them to my website. i downloaded the ffmpeg X for Mac, plus the 2 other components, but couldnt really figure out how to install the flvtool 2 ....
then, i dragged the QT and AVI files into ffmpeg X, and try to convert them, but i got weird files, which wouldnt play, even on the VLC player which i downloaded... (i tried the Invert Mapping check box, but it still didnt work..). here are the messages i get:
without checking the Invert Mapping box:
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Sun Sep 14 20:35:59 PDT 2008
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x4701fc]negative ctts, ignoring
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/Aylam-back up disk/clips for website/Autumn Dawn.mov':
Duration: 00:01:20.3, start: 0.000000, bitrate: 2054 kb/s
Stream #0.0(eng): Audio: lpcm / 0x6D63706C, 96000 Hz, mono
Stream #0.1(eng), 29.97 fps(r): Video: h264, yuv420p, 425x318
Codec type mismatch for mapping #0.0 -> #0.0
After checking the Invert Mapping box:
Sun Sep 14 20:36:48 PDT 2008
Output #0, flv, to '/Volumes/Aylam-back up disk/Autumn Dawn test1.flv':
Stream #0.0, 29.97 fps(c): Video: flv, yuv420p, 432x324, q=2-15, 200 kb/s
Stream #0.1: Audio: mp3, 22050 Hz, stereo, 56 kb/s
Stream mapping:
Stream #0.1 -> #0.0 [sync #0.0]
Stream #0.0 -> #0.1 [sync #0.1]
Unsupported codec (id=0) for input stream #0.0
any idea what i am doing wrong ??
thanks so much !!!!
My problem was -- is similar : can't encode through FFMpegX 0.0.9 y from MPEG to AVI using mencoder (under Leopard up to date).
Here is the road followed :
I recorded on my internet box a .TS file.
It came with 2 different language audio tracks.
With MPEG Streamclip, I converted it to MPEG. It still had the 2 language tracks.
In FFmpegX, I wanted to do as usual : convert it to .avi with Xvid mencoder.
I found the proper .srt subtitle file, indicated it to FFMpegX, chose one of the language tracks, applied all the usual settings, and launched the process.
But it always stops on 16% or something like that.
the partial .Avi file I get contains the good audio track, the subtitles, but it is partial.
If I choose the ffmpeg encoder, the process finishes, but I don't get the subtitles imported.
So, with a MPEG file containing two languages, a .srt subtitle file, what would you suggest to convert to Xvid .avi ?
thanks a lot
i-Moi
problems installing add'l software for ffmpegX: mencoder
By Tomtom2011 in forum ffmpegX general discussionReplies: 2Last Post: 2nd Apr 2010, 17:47 -
Problem with installing ffmpegX on MacOSX
By wlochatyjoe in forum ffmpegX general discussionReplies: 2Last Post: 11th Feb 2010, 14:06 -
[RESOLVED] ffmpegx 0.0.9y keeps asking for install of mencoder
By breggol in forum ffmpegX general discussionReplies: 1Last Post: 5th Oct 2008, 04:23 -
mencoder rotates, why not ffmpegX?
By PhilippeP in forum ffmpegX general discussionReplies: 1Last Post: 13th Apr 2008, 15:43 -
No luck with ffmpegX - mencoder segmentation fault.
By jonnymorris in forum MacReplies: 4Last Post: 2nd Mar 2008, 13:07
