Would I lose anything if I filmed on a DVX100b, but then for capturing used a cheaper camcorder (a JVC GR-244U to be exact)? This is on Vegas 8, firewire.
That depends whether the camcorder was shooting in normal DV 480i mode or in 24pA mode. Normal mode should play and transfer fine. 24pA mode may not. Experiment with Vegas in 24pA project setting.Originally Posted by ShBm
http://www.adamwilt.com/24p/
Google "24pA" or ask in a Vegas forumRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
If shooting 24p with that camcorder you should use the 24pA workflow. Otherwise, you would need to inverse telecine before import to Vegas. Read Adam Wilts report for intro, then consult Vegas Pro forums for project management tips.Originally Posted by ShBm
For example:
http://www.dvxuser.com/V6/archive/index.php
http://www.dvxuser.com/V6/archive/index.php/t-17584.htmlRecommends: Kiva.org - Loans that change lives.
Video capture through FireWire, DVX100b
By redherring2049 in forum Capturing and VCRReplies: 8Last Post: 14th Jan 2011, 00:25 -
Canon XH A1 VS Panasonic DVX100B
By eddiebaby in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 12th Nov 2008, 23:30 -
DVX100B to Vista Home Premium - Nightmare!
By Tobuscus in forum Capturing and VCRReplies: 1Last Post: 13th Oct 2007, 14:34 -
Aah! My DVX100B isn't detected in Vista... is there a fix?
By Tobuscus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 13th Oct 2007, 13:45 -
Help to review Panasonic AG-DVX100B & AG-HSC1U
By ChristianPaprika in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 8th Aug 2007, 14:07
