Hello all,
I've read many topics about joining MP4 movies, but however much I try I end up with poor results. I'm trying to join these two files (I used GSpot to get this info):
File 1:
- Video: H.264/MPEG-4 AVC, 836 kbps, 25 fps
- Audio: MPEG-4 AAC LC, 48000Hz 129 kb/s tot , stereo (2/0)
- Resolution: 640x272
File 2:
- Video: H.264/MPEG-4 AVC, 703 kbps, 25 fps
(if more info is needed I will provide it)
I tried to append the two together with Avidemux, but the resulting file had popping/clicking noises in the audio and the sync was off during the second portion. I've tried other software such as YAMB but still had the sync issue.
Some help would be immensely appreciated on how I can join them together and preserve the audio/video quality and sync, thank you!
Unless the source of your troubles is VFR (variable frame rate) the following is just a wild guess..
Since its an audio problem, you could try converting (both AAC) back to wav and then re-encode them to AC3 or back to AAC and then use:
MP4box -add file1.mp4 -add file1.aac -fps 25 -add file2.mp4 -add file2.aac -fps 25 newfile.mp4 on them.
I hope I got that command line setup correct.
-vhelp 4894
Joining x264 mp4 files issue
By dreamweaver888 in forum EditingReplies: 3Last Post: 27th Feb 2012, 19:30 -
joining mp4 files but audio out of sync
By Liselotte in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2011, 22:18 -
Joining MP4 files from youtube
By eng3 in forum Video ConversionReplies: 0Last Post: 22nd Nov 2010, 15:00 -
Joining MP4 files
By Xpenguin17 in forum EditingReplies: 2Last Post: 22nd Jul 2010, 07:23 -
joining mp4 files
By slgorin in forum EditingReplies: 3Last Post: 3rd Sep 2009, 18:47
