I wanted to convert a DVD video to .avi to play it on my DVD Player (as it does not seem to be able to play it for this zone) and I have a overscan problem. The TV is a standard PAL one and the originally, the DVD is 768 x 576. Now, I always use for some time VirtualDub to convert my DVDs so I will want to use the resize filter. Can somebody suggest me what resolution should I set for the video?
That is a 1:1 resolution, which equates to 720 x 756 at DVD resolutions.
However the resolution is not your problem. Whatever resolution you choose, the player and/or TV will expand it to fill the available space. The only way you can compensate for overscan is to add borders around the outside of the image. usually 3 - 5% is enough to get the bulk of the image back onto the screen.
You do realise that if the DVD had played, you would not have asked this question, and would have quite happily watched the same move with 3 - 5% of the image hidden.Read my blog here.
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 07:36 -
AVS Video Editor Blu-ray verification slow and "driver package" suggested.
By rjamesd05 in forum Authoring (Blu-ray)Replies: 0Last Post: 26th Mar 2010, 08:01 -
How to avoid banding in a gradient on a youtube video
By Strob in forum Video Streaming DownloadingReplies: 9Last Post: 25th Feb 2010, 13:57 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 02:57 -
H.264: higher video bitrates than suggested image size not working?
By FiD31 in forum ffmpegX general discussionReplies: 7Last Post: 23rd Jun 2007, 11:49
