Very... slowly... working... out... how... to... do... stuff...
*sigh*
I have about seven minutes of footage that I was planning to upload to YouTube, but my usual procedure with such things is to add a title card or three, to the beginnings and ends of videos. No tangible reason, it is just what I am comfortable with. Problem is, I have no idea how to do this in iMovie. What I used to do in Windows Movie Maker (blech) was to create a JPEG file in Corel Paint Shop Pro and import that, then add it to the timeline before pasting in a WAV file for music. The procedure to do this in iMovie appears inobvious, or just hidden.
I shudder to think what I am going to do about ripping DVDs and cutting that footage into chunks.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
Titles are built into iMovie. You may have the title appear "over" the video or over black before the video (or after the video). In the "over black" case, iMovie renders all the frames as an independent clip. In the case of "over the video", iMovie combines the length of the title clip with the same length of the video and renders that as a separate clip.
The actual process for doing a title varies depending on which version of iMovie you are using. If you have a new Mac with iMovie'08 (version 7.x), I'll suggest you download iMovieHD (version 6.x) as it is both easier to use and much more powerful. You must have iMovie 7 installed in order to install the earlier version of the app.
Adding Title Screen to FLV ?
By Endemoniada in forum EditingReplies: 2Last Post: 15th Aug 2010, 07:24 -
Adding 10 secs Title on a movie
By Perry Joseph in forum MacReplies: 2Last Post: 24th Apr 2009, 08:49 -
adding a logo within the title tool of premiere 6.5
By devdev in forum EditingReplies: 0Last Post: 1st Dec 2008, 15:36 -
Adding several movies to one title/menu
By dread in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 22:25 -
Adding multiple title tasks to a video
By nam207 in forum EditingReplies: 1Last Post: 22nd Nov 2007, 08:02
