i have a nonbrand Intel process computer with XP Pro that i installed SP3 and now it does the non stop continuous reboots. i can even get to reboot in safe mode. any ideas how to remove sp3? im in recovery mode now
I suggest you read this article:
http://msinfluentials.com/blogs/jesper/archive/2008/05/08/does-your-amd-based-computer...ng-xp-sp3.aspx
This might also be helpful:
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=3163197&SiteID=17
If you really have an Intel CPU, it's going to be harder to fix the endless reboot problem. The easiest fix is for HP systems with AMD CPUs that reboot because HP foolishly did not follow Microsoft's explicit instructions for how to make their installable images. -
I removed mine by going into Control Panel/Add and Remove Programs.Originally Posted by rubberman
SP3 was listed their and I just clicked it away.... -
no in the cd recovery console.Originally Posted by bendixG15
but anyway i got it to boot. -
I had problems with SP3 too. Luckily I was able solve them with a system restore. I'm not sure if it's worth the effort to try and solve the problem(s).
Can't install XP SP3
By JudgeGarth in forum ComputerReplies: 9Last Post: 5th Dec 2008, 00:07 -
XP SP3 Problems
By alegator in forum ComputerReplies: 15Last Post: 21st Jun 2008, 11:16 -
XP SP3 Questions
By CSULB71 in forum ComputerReplies: 5Last Post: 10th May 2008, 13:13 -
Windows XP SP3 being released soon.......
By Epicurus8a in forum ComputerReplies: 12Last Post: 19th Apr 2008, 16:37 -
Reminder About XP and SP3
By MOVIEGEEK in forum ComputerReplies: 17Last Post: 6th Mar 2008, 11:45
