  1. Member zootedlooter's Avatar
    Jul 2003
    BrooklynUSA
    hi guys
    i always get an error when opening folders while the thumbnails are loading...ive checked gspot and it always says codec is installed....some advice i got on another forum was to install ffdshow....but no one could tell me what to uninstall....these are the codecs i have installed
    should i uninstall everything or is there a better way to solve my problem?
    thanx
    looter
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    How about telling us exactly what the error says?
    Buy My Books
  3. Member zootedlooter's Avatar
    Jul 2003
    BrooklynUSA
    "Dr. Watson Postmortem Debugger has a problem and needs to close." it happens on video thumbnails...googling shows i am not alone but i havent found a solution there
    sorry...i am running xp sp3
    i was told that thumbnails wont load if the codec isnt installed
  4. Member zootedlooter's Avatar
    Jul 2003
    BrooklynUSA
    i know this observation is premature but....
    if no one can tell me how to fix this problem...just a solution on removing codecs will be helpful....i still want to install ffdshow
    thanx
  5. Mod Neophyte redwudz's Avatar
    USA
    You can use a program like:
    DXMan
    Codec Sniper
    DirectShow Filter Manager
    Filmerit
    These can repair or delete codecs or change their priorities. You can also use Gspot to see which codecs are installed and which ones are used with different file types. If you know the file type that is causing the problem, try rendering one with Gspot and it will tell you what processes are used. And those codecs you listed seem to be compression codecs. Your problem seems to be with the decoding part of the codecs. CODEC=(Code/Decode}
    Some of those codecs you listed are Windows system codecs and not really a good idea to remove them unless they are corrupted.
    There is also a simple workaround that works most times, just disable thumbnails in 'Folder Options'. Those type of crashes or errors are most commonly caused by Windows Explorer trying to read a file it doesn't understand.
    Or just try installing ffdshow and see if that fixes it. ffdshow isn't a codec pack and rarely causes problems.
  6. Member zootedlooter's Avatar
    Jul 2003
    BrooklynUSA
    thanx red
    ffdshow solved my problem...i wasnt sure if it would cause problems with my other codecs
