Hi
Tried using super to convert a mp4 to DV(avi) and am heppy with the quality for my purpose
Only there is a problem. the mp4 is form a NTSC clip (29.97 fps) but it looks like super will only convert it to a PAL framesize format ( even when one is able to set the framerate to 29.97)
anyone has a solution or alternative please
problem though , it lets me convert to DV PAL but when set to DV NTSC it finishes in 3 secs (0.1Mb filessize)
It displays all the correct data ( framesize, fps etc ) but it just doesnt do it
try Avanti.
ntsc_dvsd_video.tpl
replace the template in the templates folder with the above
load ntsc DV template
tripp"I'll give you five dollars if you let me throw a rock at you" -
Thanks a bunch Tripp
works as I wanted the result to be (completely conform so my other software to use the clip in isnt confused
Frankly I am amazed in the resulting quality that remains ( MP4 for online and back for sportsanalysis purposes to DV)
DJ
YouTube FLV to MP4 with SUPER?
By terrypin in forum Video ConversionReplies: 0Last Post: 28th Dec 2010, 07:06 -
AVI (DV Pal) to mp4 (h264) with FFMPEG on Windows
By Zoreil59 in forum Video ConversionReplies: 3Last Post: 17th Jun 2010, 04:35 -
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 22:05 -
mp4 to avi using SUPER
By jjbodean1970 in forum Video ConversionReplies: 3Last Post: 5th Sep 2008, 00:49 -
trying to convert an Xvid avi to mp4 w/ SUPER. audio is out of sync!
By cduval04 in forum Video ConversionReplies: 3Last Post: 10th Oct 2007, 19:45
