I have DVD9 iso file, and want to convert it to DVD5 size. Is there a way to convert this without burning to
DVD9, then ripping to TS folder, then compressing/converting?
thanks,
Win
In addition to DVD Shrink, another free program that can extract an ISO to files is 7zip
-The Mang -
Thanks for that about 7-Zip, louv68. I use it all the time and I hadn't noticed it could extract ISO files. Guess I should RTFM more often.
I also would suggest Shrink for a quick and easy backup to DVD-5. If you want more quality, DVD Rebuilder is also a option. I don't know if it can open ISOs directly, though, and it will take a fair amount longer. But it's a good choice for longer videos that may lose too much quality with Shrink.
DVD9 to DVD5
By roflwaffle in forum DVD RippingReplies: 5Last Post: 3rd Nov 2010, 17:52 -
DVD5 vs. DVD9
By Beaker14 in forum DVD RippingReplies: 1Last Post: 6th Nov 2009, 11:33 -
How do i convert an (ISO) dvd9 to a dvd5 and keep the menus???
By jcurrieirocz in forum Video ConversionReplies: 5Last Post: 26th May 2009, 09:15 -
how can i convert my dvd5 to dvd9
By scratchlikeme in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2009, 21:54 -
DVD9 To DVD5
By taylor6698 in forum DVD RippingReplies: 3Last Post: 22nd Oct 2007, 21:36
