Hi everybody,
I have Dazzle DVC 170 with s-video input 4 PIN mini-DIN
and s-video output from my digital receiver.
can I buy an s-video cable to connect my receiver to my capturing card for better picture quality rather than using the RCA cable ?
Yes, S-video has better quality than composite video, which is the term for what you call "RCA cable".
This isn't always the case. My cable box has both s-video and composite output. But s-video seems to be created from the composite signal with a simple luma/chroma splitter. It has a lot of dot crawl artifacts. The capture card I was using, a Hauppauge PVR-250, has comb filter on the composite input (to remove dot crawl) but not on the s-video input. So composite capture was actually better than s-video.
It's worth a try though. -
You need to have the option in the menu of your cablebox "ntsc/s-vhs" otherwise it's not good.It'll be like jagabo says.
Mine has this option i hope yours too*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
Full video converter 9 question about converting to hd video
By jbitakis in forum Video ConversionReplies: 6Last Post: 30th May 2012, 02:35 -
Question about Video Redo
By snafubaby in forum EditingReplies: 6Last Post: 26th Feb 2012, 05:01 -
Question About Video Only Editing
By greyhavens49420 in forum EditingReplies: 1Last Post: 1st Feb 2008, 02:18 -
question about converting rmvb video file to avi video
By jimdagys in forum Video ConversionReplies: 5Last Post: 17th Nov 2007, 00:51 -
video edition question
By kerm007 in forum EditingReplies: 5Last Post: 19th May 2007, 12:28
