Folks,
I've got 2 MAC G3 and G4 porwer PC with MAC OS 10.4
I downloaded ffmpegX,
I tried to find mpeg2enc compiled for G3 or G4. So, I decided to compile myself mjpegtools-1.9.0rc3 source
I've got an error with the the configure script :
I compiled and installed the JPEG 6b library source without error message.Code:../.. checking for jpeg_start_compress in -ljpeg... no configure: error: JPEG 6b library missing - Go to http://www.ijg.org/ [ibook:~/Desktop/mjpegtools-1.9.0rc3] administ%
However, I've got thesame error message when I try to compile mjpegtools-1.9.0rc3 source package.
Need help ...
The pre-compiled binary mpeg2enc.intel, which is suggested by ffmpegX, is a Universal Binary for both PowerPC (G3/G4/G5) and Intel (Core Duo/Core 2 Duo/Quad Core Xeon).
Very brave effort for trying to compile it yourself! 8) -
I suppose ffmpeg? (the library with CommandLineInterface, and not a GraphicUserInterface aka ffmpegX?)Originally Posted by dubis
but you forget:I compiled and installed the JPEG 6b library source without error message.at the end (sudo make install only install binaries and not library)Code:sudo make install-lib
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
Herve -- he is talking about the mpeg2enc module used by ffmpegx, not ffmpegx (or ffmpeg) itself. He apparently did not realize that mpeg2enc.intel is a universal binary, and not limited to intel machines only, so he evidently sought to compile his own version of mpeg2enc. As Case pointed out, it was unnecessary work.
oh!
(next time I will read the message more carefully
but above is the solution to compile libjpeg on OSX (first step to compile others tools)
PS to dubis : do you really want to encode videos with a G3?!? You're courageous or not in a hurry...
Well, you were helpful to me! There are some tools that I'd perhaps like to compile, so thanks for the tips!Originally Posted by Herve
And I agree -- with a G3, one must be brave, patient, or both! Good thing that he also has a G4. I have a feeling he'll quickly decide to use that Mac a bit more than the other one.
ffmpegx can't locate mpeg2enc
By sarmen2 in forum ffmpegX general discussionReplies: 10Last Post: 11th Sep 2015, 05:32 -
MPEG2ENC dowload problem
By blue439 in forum MacReplies: 7Last Post: 6th Nov 2011, 00:46 -
Problem opening mpeg2enc binary
By itegil in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2010, 22:48 -
Problem with mpeg2enc binary
By lkearl in forum ffmpegX general discussionReplies: 1Last Post: 11th Aug 2007, 03:47 -
ffmpegX not accept mpeg2enc
By aviary99 in forum MacReplies: 1Last Post: 29th Jun 2007, 22:02
