Every time that I convert the audio of my video, the resulting AC3 file is blank/silent. I've converted it with multiple programs to the same result. What's going on here? It can't be a codec issue if I can play the original file, can it?
The audio of the original file is: AAC version 4, 89.2 Kbps
Question 2:
I encoded only the second half of my video. Now I'll have the whole audio file once I can convert it. What's the best way to cut out the first half of my audio, then sync it up with the video?
I've converted files with aac audio to ac3 with winff.
Also you can use aacDECdrop.exe to convert aac to wav and then convert the wav to ac3 with aften or ffmpeg.
As far as your second question goes one way to go about it would be to convert the aac to wav with aacdecdrop then edit that wav the way you want it. Convert your new wav to ac3 with aforementioned programs. Not the most elegant of soultions but aac doesn't edit/cut very well and wav does.
Others may have different soultions but thats the best way I know.Donadagohvi (Cherokee for "Until we meet again") -
Another way to convert AAC to AC3
1. Convert (Decode) AAC to wav using Nero AAC Codec (NeroAacDec.exe) command line version.
Alternatively NeroAAC UI can be used if you don't want to use command line.
2. Convert wav to ac3 using Eac3to.
Alternatively EAC3to conversion utility if you like GUI.Last edited by newyear1967; 15th Feb 2010 at 22:41.
Please stop bringing up old posts,if you cant see the dates they were posted then update to the newest ie or firefox,you can also write a guide and submit it so you dont have to keep posting your instructions.
Losing audio when authoring TV shows recorded using WinTV
By rkeberdle in forum Newbie / General discussionsReplies: 5Last Post: 22nd Dec 2011, 20:53 -
Converting the audio of an .mkv from AC3 to AAC
By Anonymous4453 in forum Video ConversionReplies: 9Last Post: 13th Nov 2011, 10:39 -
Audio encoding AAC to AC3 for multiAVCHD authoring
By ejai in forum Authoring (Blu-ray)Replies: 6Last Post: 3rd Dec 2010, 11:00 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19 -
Losing audio data converting AC3 to MP3, Help!
By blueprint in forum AudioReplies: 8Last Post: 24th May 2007, 14:55
