I have some good flv movies but i wish to crop the left side and right side by a few pixels (67 to be precise).
Which tool can i use?
Will it affect the qiality of the output?
I do not mind onverting to mpg (my fiinal output format and then cropping but would the quality be affected more that way
If i crop and resize in a single operation am i right in assumin that cropping is done first followed by resizing and not the other way around?
It depends on the tool as to what order things happen in. If you are converting to mpeg then you would be best to use something like virtualdub with the flv plugin. Crop first, then resize, then frameserve to your mpeg2 encoder. This will minimise quality loss by forcing only a single re-encode.
Read my blog here.
FLV Extract Cropping Error
By TAS257 in forum Newbie / General discussionsReplies: 8Last Post: 26th Apr 2012, 21:55 -
Help with FLV (AviDemux) - Cropping 8 pixels from right...
By tigerb in forum Newbie / General discussionsReplies: 8Last Post: 28th Aug 2010, 16:23 -
Lossless cropping tool?
By mpalm887 in forum Video ConversionReplies: 4Last Post: 24th May 2009, 09:44 -
video clipping and cropping tool
By greendesert in forum EditingReplies: 8Last Post: 7th Apr 2009, 06:25 -
recommended cropping tool
By marcopolo1 in forum EditingReplies: 7Last Post: 26th Aug 2007, 05:25
