In WinXP, I've been playing with FFmpeg, Mplayer and Mencoder doing file conversion of flv, RMVB, DVD etc... for the past couple of months with good results, using either bat files or command line parsing in VB it''s surprising what you can achieve.
What I'd like to try now is to video capture using a generic bt878 capture card but the examples I found are in Linux. I need Window equivalents and I can't get past the Device driver ID.
ie... (a partial line)
mencoder tv:// -tv driver=******:width=640:height=480:channel=3:norm=ntsc etc.....
The dos feedback box says that it doesn't recognize the capture device no matter what I put to replace the (****) in the line above. It just responds "no such driver". I tried using the name I saw in virtualdub wdm driver window (Conexant Capture" and "Conexant Capture(DirectShow)" and other similar names reported by other capture programs but I get the same message.
If I can get past this issue the rest should be easy to figure out.
Any suggestions?
Results 1 to 1 of 1
Problems with creating a timelapse video using mencoder/Mplayer with WinXP
By W.Lewin in forum Video ConversionReplies: 7Last Post: 31st May 2011, 11:11 -
MPLAYER pipe to MENCODER possible?
By neapandele in forum Newbie / General discussionsReplies: 0Last Post: 27th Oct 2009, 05:56 -
QT movie with 2 video tracks to FLV with mencoder or ffmpeg
By bluehz in forum Video ConversionReplies: 0Last Post: 26th Mar 2008, 15:39 -
mencoder and mplayer packages
By mattr in forum ffmpegX general discussionReplies: 1Last Post: 30th Dec 2007, 08:05 -
How to add watermark to a video with mencoder or how to scale with FFmpeg?
By ApplePro in forum Video ConversionReplies: 16Last Post: 21st Nov 2007, 09:12
