In The Name Of God
Hello
I'll be so Thankfull if you guide me ;
I want to capture NTSC video from a composite input .
I use mencoder i face an error ,see :
regards dehqanCode:debian:~# mplayer mencoder -tv norm=NTSC:driver=v4l2:width=720:height=480:input=1:fps=29.97 tv:// -oac lavc -ovc lavc -of mpeg -mpegopts format=dvd -vf pp=lb/ha/va/dr,hqdn3d,harddup -srate 48000 -af lavcresample=48000 -lavcopts vcodec=mpeg2video:vrc_buf_size=1500:vrc_maxrate=8000:vbitrate=7000:keyint=15:acodec=mp2:abitrate=192:aspect=4/3 -o capture.mpg MPlayer 1.0rc1-4.1.2-DFSG-free (C) 2000-2006 MPlayer Team CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz (Family: 15, Model: 3, Stepping: 3) CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled with runtime CPU detection. Unknown option on the command line: -oac Error parsing option on the command line: -oac
In The name Of godOriginally Posted by 45tripp
Hello
inshalla ,irani hastid ?
Thanks alot for you'r attention .
Do you mean this ?
or :Code:debian:~# mplayer mencoder MPlayer 1.0rc1-4.1.2-DFSG-free (C) 2000-2006 MPlayer Team CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz (Family: 15, Model: 3, Stepping: 3) CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled with runtime CPU detection. mplayer: could not connect to socket mplayer: No such file or directory Failed to open LIRC support. You will not be able to use your remote control. Playing mencoder. File not found: 'mencoder' Failed to open mencoder. Exiting... (End of file)
which one do you mean ?Code:debian:~# mencoder bash: mencoder: command not found
reagrds dehqan[/quote] -
no,Originally Posted by a.dehqan
but the word is used in my local dialect, as are many other foreign words...
so in fact you do not have mencoder...Originally Posted by a.dehqan
mplayer is one thing and mencoder another...
see if you can get a package of it.
i'm on windows, so i can't really help you out.
should find a package here though:
http://www.debian-multimedia.org/pool/main/
probably best to compile your own.
but that can often be painful.
gl
tripp"I'll give you five dollars if you let me throw a rock at you"
Mencoder (Ubuntu) with Logilink Video Grabber VG0001 -> video buffer full
By Dobi in forum Capturing and VCRReplies: 0Last Post: 6th Jul 2010, 10:52 -
Capturing VHS with MEncoder (Help)
By the98 in forum Capturing and VCRReplies: 10Last Post: 9th Mar 2010, 10:14 -
Mencoder // ffmpeg flv file Audio-video sync problem
By krishnareddy in forum ffmpegX general discussionReplies: 5Last Post: 26th Apr 2009, 09:13 -
Mencoder - Audio / Video Sync Problem
By krishnareddy in forum Video ConversionReplies: 0Last Post: 21st Apr 2009, 23:05 -
mencoder options NTSC 29.97 -> PAL 25 fps with a/v sync
By menket in forum Video ConversionReplies: 3Last Post: 8th Oct 2008, 07:04
