I want to cut out a few seconds from the last video (.vob) file of the authored DVD (to make it fit into the DVD-r.)
I followed the directions of the sticky (via VOBedit/MPEG Video Wizard) but how do I mux it back?
I managed to mux it back via VOBEdit but playback of the movie via my DVD player ends right where the last .vob begins and there is no chapter navigation for the last 5-10 minutes of the video. Is there a setting I must configure in IFOedit or something?
Thanks in advance.![]()
I don't know anything about the sticky or the method it uses, but this is easily done with VobBlanker. Use the Prev/Cut button on the last cell, cut out the ending, and Process it. Here's a guide:
http://jsoto.posunplugged.com/guides/VobBlanker/prevcut/index.php
You can also do this in DVD Shrink by reauthoring it with the last part cut out and no compression. That will get you the movie with no menus. You'll then stick it back into the original DVD with VobBlanker. Here's a guide:
http://jsoto.posunplugged.com/guides/VobBlanker/adding_menus/index.htm
The first way is easier and faster, though, but if you already have the movie minus the end from following the sticky (and nothing got screwed up in the process), then this 2nd guide will be a better way than VobEdit to get it back into the original DVD, thus getting back the menus and anything else in there you might want to keep. -
If it's just seconds you want to cut, why not keep them and keep your project simple by just shrinking the movie?
Authored DVD plays 3 seconds audio/No video
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 6th Jan 2011, 14:26 -
Help will pulling video from DVD's to edit than Back to DVD
By Deter in forum Authoring (DVD)Replies: 9Last Post: 2nd Jan 2010, 23:30 -
Replacing Video on Authored DVD
By videopromaster in forum Authoring (DVD)Replies: 6Last Post: 31st Jul 2008, 12:52 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 13:13 -
Burn an already authored DVD-Video folder(VIDEO_TS)
By jain30 in forum Authoring (DVD)Replies: 2Last Post: 12th Jul 2007, 09:02
