Is there any way to tell convertXtoDVD that it's OK to erase the DVD-RW disc in the burner *before* it starts encoding? I always set it running and then when I come back it says "disc not empty ... OK to erase?" and I have to click OK and then wait another 10 minutes for the RW to burn. I would expect it to be an option under the Burning tab, but I don't see it anywhere.
thanks,
-LH
Thanks for the reply ... I've actually tried that, but with ImgTool Burn instead of ImgBurn ... and it didn't work - even after erasing, ConvertX says "the disc is not empty". I'll try ImgBurn I guess, but it sure seems like a simple checkbox somewhere on ConvertX would be helpful.Originally Posted by guns1inger
Yep, I just figured that out 5 minutes ago and came over here to post a big fat "NEVER MIND". Apparently I hadn't upgraded in a while. Now it gives the warning once with a checkbox saying "always erase rewritable media without warning".Originally Posted by MysticE
Thanks all ... sorry to bother you.
Is it possible to erase a DVD+R?
By Han Solo1 in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2010, 14:54 -
convertx to dvd file size
By dvd1304 in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2009, 15:39 -
Do I need to change AVI frame sizes before convertx to DVD
By johnharlin in forum Newbie / General discussionsReplies: 6Last Post: 18th Nov 2008, 20:58 -
convertx to dvd
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2008, 14:54 -
Can't erase my DVD-RW disc
By hurtstotalktoyou in forum DVD & Blu-ray WritersReplies: 4Last Post: 15th Nov 2007, 10:40
