Hi folks.
Im having trouble burning DVDs, though not Cds with my laptop. I keep getting that message. Im not using the best quality blank dvds but it is the ones ive mostly used and they burned fine up until yesterday. I have pasted the nero log below. Any help would be appreciated, this has happened at the worst possible time for me.
Thanks.
me
4C87-2018-2045-477K-055X-403E-9539-**** (*)
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 12:54:32 PM
NT-SPTI used
Nero Version: 7.5.13.1
Internal Version: 7, 5, 13, 1
(Nero Express)
Recorder: <HL-DT-ST DVD+-RW GSA-T11N>Version: A103 - HA 1 TA 0 - 7.5.13.1
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <HL-DT-ST DVD+-RW GSA-T11N>Version: A103 - HA 1 TA 0 - 7.5.13.1
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG HM160JI atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVD+-RW GSA-T11N atapi Port 1 ID 0 DMA: On
CdRomPeripheral : PQ5401K JMX680J 1.01 amg89kwx Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVD+-RW GSA-T11N D: CDRom0
PQ5401K JMX680J F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1014MB (1038712kB)
Free physical memory: 404MB (414216kB)
Memory in use : 60 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.9.2008
UDF/ISO compilation
3:21:01 PM #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
3:21:01 PM #2 Phase 112 File dlgbrnst.cpp, Line 1760
DVD-Video files reallocation started
3:21:01 PM #3 Phase 114 File dlgbrnst.cpp, Line 1760
DVD-Video files reallocation completed (no file modified)
3:21:01 PM #4 Text 0 File Isodoc.cpp, Line 6517
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
3:21:01 PM #5 Phase 111 File dlgbrnst.cpp, Line 1760
DVD-Video files sorted
3:21:01 PM #6 ISO9660GEN -11 File Geniso.cpp, Line 3332
First writeable address = 0 (0x00000000)
3:21:01 PM #7 ISO9660GEN -11 File Geniso.cpp, Line 3332
3:21:01 PM #8 Text 0 File Burncd.cpp, Line 3467
Turn on Disc-At-Once, using DVD media
3:21:02 PM #9 Text 0 File DlgWaitCD.cpp, Line 306
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 167263 ( 37:10.13, 326MB)
3:21:02 PM #10 Text 0 File DlgWaitCD.cpp, Line 318
Write in overburning mode: NO (enabled: CD)
3:21:02 PM #11 Text 0 File DlgWaitCD.cpp, Line 2929
Recorder: HL-DT-ST DVD+-RW GSA-T11N, Media type: DVD-R
Disc Manufacturer: RITEKF - 1
Disc Application Code: 64, Disc Physical Code: 193
3:21:02 PM #12 Text 0 File DlgWaitCD.cpp, Line 490
>>> Protocol of DlgWaitCD activities: <<<
3:21:02 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 792
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 167264 (167264) = #167264/37:10.14
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 167264 blocks [D: HL-DT-ST DVD+-RW GSA-T11N]
3:21:02 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [D: HL-DT-ST DVD+-RW GSA-T11N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 342556672, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 167264 | 0 | 0x00
0 | 1 | 1 | 0x41 | 167264 | 0 | 0x00
167264 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
3:21:02 PM #15 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
3:21:02 PM #16 Phase 24 File dlgbrnst.cpp, Line 1760
Caching of files started
3:21:02 PM #17 Text 0 File Burncd.cpp, Line 4351
Cache writing successful.
3:21:02 PM #18 Phase 25 File dlgbrnst.cpp, Line 1760
Caching of files completed
3:21:02 PM #19 Phase 36 File dlgbrnst.cpp, Line 1760
Burn process started at 8x (11,080 KB/s)
3:21:02 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
3:21:02 PM #21 Text 0 File DVDR.cpp, Line 3092
Recording mode: Sequential Recording Mode
3:21:02 PM #22 Text 0 File DVDR.cpp, Line 3248
Start write address at LBA 0
DVD high compatibility mode: Yes
3:21:02 PM #23 Text 0 File Cdrdrv.cpp, Line 9261
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
3:21:12 PM #24 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 10 32 4D 03 0C 0C
Buffer x22030040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3:21:12 PM #25 CDR -1135 File Writer.cpp, Line 299
Write error
3:21:13 PM #26 Text 0 File DVDR.cpp, Line 3468
EndDAO: Last written address was -1
3:21:13 PM #27 CDR -1135 File WriterStatus.cpp, Line 162
Write error
3:21:13 PM #28 TRANSFER -24 File WriterStatus.cpp, Line 162
Could not perform end of Disc-at-once
3:21:15 PM #29 Phase 38 File dlgbrnst.cpp, Line 1760
Burn process failed at 8x (11,080 KB/s)
3:21:16 PM #30 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
3:21:18 PM #31 Text 0 File Cdrdrv.cpp, Line 10538
DriveLocker: UnLockVolume completed
3:21:18 PM #32 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/17/2001 2:07:32 PM
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 10/5/2006 3:42:42 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.67a, size=43872 bytes, created 2/23/2008 3:38:33 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
This appears to be the error:
That usually means the drive is in PIO mode, though it shows as DMA mode in the log.3:21:12 PM #24 SPTI -1135 File SCSIPassThrough.cpp, Line 179
A second drive is showing up in PIO mode, though:
All drives should be in DMA mode.CdRomPeripheral : PQ5401K JMX680J 1.01 amg89kwx Port 2 ID 0 DMA: Off
The 'Could not perform end of Disc-at-once' is not really the error, but the result of it.
I would go to your Device Manager and check the DMA mode of your drives:
But I would also try a different brand of DVD media. It's possible the quality of the media has changed. This can happen even in the same batch with some DVD media. Easy enough to test, try some Verbatim or TY DVD media and see if there is any improvement.To check DMA/PIO mode within Windows:
Control Panel>System>Hardware>Device Manager>IDE ATA/ATAPI controllers.
From there, right click on one of the channels and choose 'Properties>Advanced Settings'. All drives should be DMA mode. The 'Current Transfer Mode' for Hard drives is usually DMA 4-6 and DVD burners DMA 2-4, DVD ROMs usually DMA 2. If you see any in PIO mode, that can slow things down.
Changing them back may be easy or complicated. First see if you can change them in that window. If not, I usually uninstall the channel the drive is on and let the OS reinstall it. This will usually take a reboot. This will not damage any files on the computer.
Alternatively, since Nero seems to have finished creating the file, you might try ImgBurn to burn it instead, though you may get a similar error.
DVDs and CDs use different lasers for burning. While CDs may work with a drive, DVDs may have problems.
But if nothing else has changed, I suspect a media problem.
Hi. Thanks very much for your detailed response.
I got some better media from a friend half an hour ago, tried that and got the same result.
I followed the DMA instructions. On the primary and secondary channels the option was "DMA if available" and it was already selected on both of them. Im not sure where that DMA off on the nero log comes from and i only have one drive if that helps any???
Thanks again redwudz.
Matshita BD UJ240AS doesn't work (not perform start of Disc-at-once)
By whenloverageswild in forum Authoring (Blu-ray)Replies: 5Last Post: 11th Nov 2011, 03:08 -
Burning DVD Could not perform end of disk-at-once
By jasonkral in forum Authoring (DVD)Replies: 8Last Post: 14th Feb 2011, 00:05 -
By smt16 in forum DVD RippingReplies: 1Last Post: 18th Jun 2010, 06:50 -
Could not perform end of disc-at-once on dual layer dvd only
By Subhash in forum DVD & Blu-ray WritersReplies: 20Last Post: 25th May 2009, 14:09 -
Error: Could not perform end of Disc-at-once - Please Help
By patrickj0781 in forum ComputerReplies: 7Last Post: 20th Jun 2007, 20:28
