How to convert rmvb files to a QuickTime compatible format using ffmpegX?
Macintosh G5/1.8, 2giga RAM, MacOS 10.4.11
- Install reallib (PowerPC version, because you have a G5), like described on the site.
- Rename .rmvb to .rm to maximize compatibility.
- Open the source file in ffmpegX.
- Test if the file is fully recognized/supported by trying the [Play] button in the upper right corner of the ffmpegX window. (Use the [q]-key to quit mplayer when you've seen enough; not the window-close button, which can cause an application crash for mplayer.)
- Select a mencoder preset to convert to mpeg-4 (h.264/DivX/XviD).
- Encode.
Thanks for responding.
I have reallib installed.
I changed the rmvb extension to rm and I tested the play button and the file was fully recognized.
Even so, the conversion process is stopped after decoding 1/3 of the rm file.
What could be wrong? I always decoded real media with ffmpegX but this time it is not working.
If you don't mind, I am attaching the process info file that reports some errors that I don't understand what they are but maybe you could.
Thanks again for your help
process%20info.txt
The log shows ffmpegX thinks the source file is 29.000 fps and loads of duplicate frames. Try verifying the framerate in RealPlayer (Cmd-I). If RealPlayer says a different fps, then ffmpegX may have read a wrong value. Copy the value from RealPlayer's Clip Info to the ffmpegX target framerate setting in the Video tab.
The lines "1 duplicate frame(s)! 1 duplicate frame(s)!", at the end of the log, are not a stopping error in itself, like it is still busy?
The errors at the start of the log are just the way the decoder works: trying different settings, until one is found that works. Those are not errors that could stop a running process.
You could try running an encode with "Open Terminal Window", to see if that catches the reason why it stops at 1/3, or perhaps continues after that.
Thanks for all the help but that particular rmvb file is impossible to convert, I think.
I tried running an encode with "Open Terminal Window" (the last 2 lines are attached to this msg).
I think the bit rate is variable and so is the frame rate. You can see for yourself.
And I succeeded encoding an original rm file, much smaller, without any problem.
Is there any other software that could do the job?
terminal%202%20last%20lines.txt
You could hijack it with iShowU while playing in RealPlayer.Originally Posted by oicram
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 10:07 -
Quicktime and ffdshow can't convert some files.
By joecanada in forum Video ConversionReplies: 0Last Post: 15th May 2009, 17:30 -
How to Convert Quicktime MOV Video Files to MPEG-2
By hiroprot in forum Video ConversionReplies: 8Last Post: 10th Nov 2008, 09:54 -
How to Convert Popular Video Formats to RealMedia Files (eg: rmvb)?
By devilcoelhodog in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2008, 21:09 -
How do i convert rmvb to wmv?
By jimnim in forum Video ConversionReplies: 1Last Post: 8th Jun 2007, 23:22
