I have a DVD that has confusing names (viewed in a software player) for the audio tracks... I'd like to rename them, something like this (and then re-burn):
current audio track names -----> new audio track names
Chinese (Taiwan) ---------------> No commentary
English (United States) ---------> English commentary
Chinese (Taiwan) ---------------> Cantonese Chinese commentary
Chinese (Taiwan) ---------------> Mandarin Chinese commentary
Is it complicated to do this? Or is it something that can be easily done, say, just by re-writing the ifo files or something along those lines?
(Hopefully, you can just point me to a program and say "go, figure it out yourself within that program..)
Also, a related question -- if I want to change the default language track (right now it is the first one) while still keeping the other ones, I take it DVD Studio Pro is the only way to go? ( https://forum.videohelp.com/topic354810.html?highlight=dvd%20audio%20track%20title )
Many thanks!
(please excuse the asterisks and arrows above, couldn't use tabs and blank spaces to make that chart..)
Thanks for your extremely quick reply, I really appreciate it! I will take a look at PGCEdit. Thanks again.Originally Posted by guns1inger
Have a look at this link : http://download.videohelp.com/r0lZ/pgcedit/doc/PgcEdit_manual_3.htm#PGC_Editor for re-assigning streams and stream types
Read my blog here.
@guns1inger:
Thanks! I looked at pgcedit, and that little program looks very powerful but complicated for its size. I was about to resign myself to the learning curve, but your link takes me right to the problem. It looks pretty easy from those instructions. Thanks for all of your help.
@tinker:
I should have described my problem more clearly. I do want to rename the tracks in menu, but, the DVD actually doesn't have any kind of onscreen menu (very bare bones), it's just in the software player's own right-click context menus that the language tracks appear and are selectable from.
@guns1inger:
You were right about the language codes pgcedit uses being possibly kind of restrictive. It seems to use ISO 639-1, which is actually somewhat more restrictive than what's currently on the DVD. I'm looking into that right now.
Thanks again, both.
It uses the ISO 639-1 for the language (English, French, etc), but beside the field where you enter the language code, there is also a drop-down box for selecting optional tags (normal, for visual impaired, director comment).
PGCEdit -> Domain -> Domain Streams Attributes
editing existing chapter names in mkv and muxing it
By ratatouille in forum Video ConversionReplies: 0Last Post: 13th Jan 2012, 06:22 -
Change subtitles names in MultiAVCHD so that these names appear on tv
By Delta007bhd in forum SubtitleReplies: 0Last Post: 20th Sep 2011, 13:53 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
How do you change the order of audio tracks?
By FallenAngelII in forum DVD RippingReplies: 0Last Post: 29th Mar 2010, 06:22 -
change mp4 stream names
By Sem in forum Video ConversionReplies: 0Last Post: 5th Jun 2009, 13:31
