A friend gave me a DVD that he authored with Encore CS3 to duplicate some discs for him. I always check to make sure a disc is good before I duplicate it. I noticed that it wasn't closed (finalized) so I made a copy and finalized it. I downloaded the Encore CS3 manual to see if it had any comment on this but found nothing. Does anyone know what to look for regarding closing a DVD when burning from Encore CS3?
Some info on the Adobe Forums here:
http://www.adobeforums.com/webx?14@@.3c05e742/1
From the link above:
Well, I just spoke to Adobe support and apparently they updated the burning engine in Encore CS3. The guy said the new engine will NOT close DVD's.
Ugh! My solution is to use Encore CS3 to create an image file, then use Roxio or Nero to burn the image file to DVD.
This is NOT what I was hoping for, but it looks like I'm screwed because this 'non closing' issue isn't a concern for Adobe, which sucks because it IS an issue for me
Good Luck....
How do you use Adobe Encore CS3?
By Banleno007 in forum Authoring (DVD)Replies: 2Last Post: 20th Feb 2012, 11:33 -
Encore CS3 or DVD Lab PRO 2
By grzegorz in forum Authoring (DVD)Replies: 12Last Post: 17th Oct 2010, 08:14 -
Exporting from Premiere CS3 on PC to use in Encore CS3 on Mac
By meltait in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2008, 14:15 -
Encore CS3 Libraries
By vin4evr in forum Authoring (DVD)Replies: 0Last Post: 20th Feb 2008, 10:46 -
Encore CS3 & DVD Studio Pro comparison in master quality
By Joybreaker in forum Authoring (DVD)Replies: 5Last Post: 14th Feb 2008, 12:56
