i have a AOpen DUW1616/ARR and it doesnt want to read DVD type disks. it reads CDs fine.
any suggestions?
Perhaps the lens needs cleaning
or a symptom of a dying dvd burner
good news is . DVD burners are cheap . less than $30 for a new one
i sure hope it isnt dying. its barely been used. i got it a few years ago but i didnt use it till receantly...it kinda stopped working after the power went out, could it have fryed itself?
I'm not sure if this will help.
try under Device Manger to uninstall,and install the driver again.
reads CDs fine,and not DVD's sound like dvd optical is bad
wait for more responds from other forum members. -
Definitely try the remove/reinstall drivers attempt first; you might get lucky. Check to see if it can mount data DVD discs -- if it can, but only refuses to recognize DVDs, then something besides hardware is going on. If no DVD ever gets recognized, then things look grimmer. Some drives use two separate lasers (an IR one for CD, a red one for DVD; this maximizes compatibility with different media and brands), and if the red one goes bad, you get precisely the symptom you are describing. If that turns out to be the case, replacement is your only option. Luckily, as has been pointed out, new ones are not that expensive.
ok, thanks for your help.
there not expensive so i wont waste time figuring out this thing
thanks again.
LITEON LVW-5045 cannot read DVD-R disks
By elfie-gow in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Jan 2011, 17:58 -
My computer doesn't read dvd+rw disk
By jayjayj2 in forum Newbie / General discussionsReplies: 0Last Post: 17th Sep 2008, 13:05 -
AOpen DUW1616/ARR Won't Burn DVD-9
By Crimson42 in forum DVD & Blu-ray WritersReplies: 4Last Post: 9th Sep 2008, 17:40 -
DvD R9 burns disks ok but cant read them
By craftycelt in forum Newbie / General discussionsReplies: 6Last Post: 1st Mar 2008, 18:56 -
Video Type Doesn't Match prob when compiling DVD Lab Pro project
By ulrichburke in forum Authoring (DVD)Replies: 6Last Post: 11th Dec 2007, 14:31
