I was about to rip another dvd then...
As far as i know we should never change the region code of our dvdplayer, cause we have a limit to o that.
What should i do?????
If you're not sure, don't set it and just click ok on that last panel. That's what I do and so far no problem. Just noticed you still have 5 changes available, that means you've never set the region on that drive. It should still be able to decrypt, but you won't be able to play any movies with it until you set it.
It did decrypted the DVD and its plays it cause the DVD is "All Regions" i wonder why DVDDecrypter asked for that.
Probably it cant play dvds with region lock, whatever i only put dvds on my laptop to decrypt them so no big deal.
Thanks nic2k4 for the tips
Being able to set region code in LG BD550 blu ray player
By bevivek in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2011, 06:11 -
Change of Region Code incorrectly set on DVD player
By cashey007 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 12th Mar 2010, 21:12 -
Region Code Samsung ht-bd1220 - Code does not work
By mhschenk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Oct 2009, 14:44 -
DVDDecrypter wants to set Region Code
By src2206 in forum DVD RippingReplies: 6Last Post: 15th Feb 2009, 11:38 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 12:42
