Hi there,
I'm trying to convert a bunch of Real Movie files (.rm) to use on my Ipod Video. I've installed the reallib files a documented elsewhere on the forums and when I drag one of the .rm files into ffmpegx it now recognises the file. However, when I go to convert the file using MPEG4 (.AVI) (mencoder), with the all the default settings, I get the following error:
Opening video decoder: [realvid] RealVideo decoder
Read the RealVideo section of the DOCS!
Error: dlopen(/Library/Application Support/ffmpegX/reallib/drvc.so, 1): no suitable image found. Did find:
/Library/Application Support/ffmpegX/reallib/drvc.so: unknown file type, first eight bytes: 0x7F 0x45 0x4C 0x46 0x01 0x01 0x01 0x00
VDecoder init failed
Selected video codec: [rv40mac] vfm: realvid (Mac OS X RealPlayer 9 RV40 decoder)
Forcing output fourcc to 58564944 [DIVX]
Error: dlopen(/Library/Application Support/ffmpegX/reallib/drv4.so.6.0, 1): image not found
Audio format 0x72706973 is incompatible with '-oac copy', please try '-oac pcm' instead or use '-fafmttag' to override it.
I'd really appreciate some help here if anyone know why I'm getting this issue please.
Many thanks.
Cheers!
0x72706973 (rasiprmac) audio doesn't seem to have the same support as other audio codecs in .rm files. Actually, I haven't seen such as .rm file before. Can I download such a .rm file from somewhere, to do some tests?Originally Posted by spadgham
The hints given are for the command line, I doubt the current ffmpegX GUI can overcome it...
Real Media can be a real pain to convert to other formats, which is why I try to avoid .rm whenever possible.
Problems with conversion from wmv to MP4
By Dr_Zocki in forum MacReplies: 2Last Post: 9th Feb 2010, 04:27 -
MKV [h264/aac] to mp4 conversion problems...
By DestructoEH in forum Video ConversionReplies: 6Last Post: 12th May 2009, 19:19 -
DVD to MP4 - Conversion problems with 4Media Convertor
By thom2 in forum DVD RippingReplies: 8Last Post: 10th Oct 2008, 01:59 -
No audio w/ MP4 to AVI conversion in 0.0.9y (worked fine in 0.0.9v)
By rmerkley in forum ffmpegX general discussionReplies: 6Last Post: 8th Jun 2008, 23:16 -
DVD->MP4 conversion quality problems - Need your advise
By amir77a in forum DVD RippingReplies: 6Last Post: 1st Jun 2007, 02:27
