Hi, here's my question:
I want to record a movie from TV and sync this audio with a DVD video of the same movie.
The idea is to author a DVD adding that new language track.
My standalone-DVD device only records at 29,970 FPS.
The problem is, the DVD movie plays at 23,976.
If I get audio and video to start at the same point, they will progressively loose sync.
If I use an audio edit tool to shrink the audio from TV and fit the DVD, the pitch is changed because
the large difference of speed.
If I choose the "preserve pitch" option, this will result in a weird slower speaking pace.
So I will appreciate any ideas.
Thanks!
Even if you somehow get the frame rates to be the same, if there are any differences in the TV and DVD versions (maybe it's impossible for you to edit the TV version so it is exactly the same as the DVD), they will never be in sync. You should NOT have to change pitch or speed for audio between 23.976 fps and 29.97 fps. They are going out of sync probably because the length of the TV version is different from the length of the DVD version.
Well I've seen a lot of home-made custom DVDs being adverted with this featureOriginally Posted by jman98
So I think it's possible to do it, just can't figure out how..
Maybe to cut out the commercials and synchronize part by part?
Thanks!
Synchronize Audio and Video from Different Sources
By Bruno AUgusto in forum AudioReplies: 2Last Post: 22nd Nov 2011, 18:27 -
Can't synchronize audio/video with Vegas
By dexter30 in forum EditingReplies: 1Last Post: 2nd Oct 2009, 16:05 -
Synchronize Audio in Vegas 8?
By MadisonMax in forum EditingReplies: 3Last Post: 30th Aug 2008, 01:56 -
Audio from movies with non-standard framerates.
By Maikeru-sama in forum Authoring (DVD)Replies: 16Last Post: 30th May 2008, 17:21 -
synchronize/edit 2 audio tracks
By volam in forum AudioReplies: 1Last Post: 28th May 2008, 13:01
