Results 31 to 35 of 35
hey ive also tried googling this with no real results
i found a site called http://pdfjpg.de/ but i cant open the file created on my computer or the image is altered
then there are some other sites but they are all very confusing :/
could someone please tell me a decent site for this, what i thought, should be a simple task...
regards -
^ "STDU Viewer" can convert all the pages of a PDF to standalone images.
If you decide to use it, I recommend that you first export to PNGs, and later batch-recompress to JPGs with a software that allows the user to choose the compression/quality level (e.g., IrfanView).Last edited by El Heggunte; 1st Oct 2013 at 08:00. Reason: better wording :-/
PDF to image:
1) Photoshop. Or Photoshop Elements.
2) Adobe Reader - some early version like 9 with the "Snapshot" tool. Select area, then zoom in (to 1600% if you want), right click, copy.
Image to PDF:
Any PDF Print driver, such as PrimoPDF.
Both, for hardcore geeks: Ghostscript.
(I'm aware that this thread is 3228 days old but I still want to reply.) -
Print Screen key and paste into Windows Paint, or Windows Snapping Tool.
Easy way to convert PDF to Excel?
By Soccerman77 in forum ComputerReplies: 2Last Post: 9th Nov 2010, 19:17 -
VOB convert to jpg
By kevinguyen in forum Video ConversionReplies: 0Last Post: 10th Nov 2009, 15:49 -
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 29th Nov 2008, 15:13 -
How do I convert PDF to JPG? Thanks in advance.
By gary11364 in forum ComputerReplies: 1Last Post: 12th Oct 2008, 10:08 -
How to convert E-Book in PDF Format to VCD or DVD
By permataharahap in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2008, 00:00
